Rca 32" RLDED3258A-c only powers up momentarily.
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    Rca 32" RLDED3258a-c will flash the logo momentarily and then shut off.I have verified leds all come on and voltage is around 37vdc however it quickly shuts down and don't get stable dc voltage.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Rca 32" RLDED3258A-c only powers up momentarily.
    May be worth looking at this Youtube video. Says the led voltage is 71V
    https://www.youtube.com/watch?v=GrfSmtzFjCc
      Pictures of what we are dealing with? Please upload good clear pictures of the whole backside of the TV showing all the boards, and good clear pictures of the connectors that show the pinout of the connectors.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Sounds like a typical LED Backlight failure issue, to me.
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          Got those pics for you bud.
          • sputnikoff
            • Feb 2016
            • 203
            • canada
            also
              Only one board?
              Leave the meter probes on the two legs of capacitor EB801 in that LED driver circuit and then turn on the TV while watching the meter to see how high the DCV jumps up to and settles down to after 10 second, the repeat the same test but without the LED connector in place.
              • CapLeaker
                Leaking Member
                • 8352
                Yeah, RCA has been doing this "all in one board" design for a few years now. To 90% all these RCA's have backlight failures, because you can't adjust the backlight in the menu. It is always running at full tilt.
                • sputnikoff
                  • Feb 2016
                  • 203
                  • canada
                  Hi Budid some test and found voltage in off condition is 27 vdc and with power on jumps to 65 for 2-3 sec then slowly bleeds back to 27.With connector off its still 27vdc but jumps to 105 and stays for maybe 2 sec then bleeds back down again.I did check with panel lifted prior and all lamps seemed to light but was very quick.
                    Well the Boost converter is working, the input Voltage to the boost converter is 27V, so when the LED driver shuts down you will only see the feeding the Voltage of 27 V.
                    105 V without LED connector in place and 65 V with connector is place shows that it does see the Load (LED's) but somehow it goes into shutdown.
                    You may have to find out next if the BL-ON and the Dim control signals are gone or not when the Backlights go off, this will be hard since it is all in one board so I doubt that there will be any test point labels for those two signals.
                    https://www.shopjimmy.com/catalogsea...Rca+RLDED3258A
                    • sputnikoff
                      • Feb 2016
                      • 203
                      • canada
                      Your knowledge on this stuff is impressive for sure.I will do further testing ,thanks again for your dedication.
                      • neilc6
                        • Nov 2015
                        • 1550
                        You can adjust the backlight but you need to go into the service menu. With TV on, MENU-1-1-4-7 Under panel settings. Eeprom failure is also common in these all-in-one board models
                        • sputnikoff
                          • Feb 2016
                          • 203
                          • canada
                          Hey bud Did some further checks used 0v battery on each string and got roughly 130-140 ma on each string.So no surprize bac to main board.
                          • CapLeaker
                            Leaking Member
                            • 8352
                            0V battery?
                            • sputnikoff
                              • Feb 2016
                              • 203
                              • canada
                              ya misprint lol home with massive flu.I used 9 volt battery and leds all light up leds really well.
                              • nosaj
                                Samsung QN82Q70RA powers on then powers off
                                by nosaj
                                I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
                                So I thought I'd just quit messing around and come to the best site...
                                11-07-2025, 04:58 PM
                              • lostone
                                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                by lostone
                                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                05-19-2024, 11:40 AM
                              • malogro
                                Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                by malogro
                                Hello all,
                                I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                Intro:
                                This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                04-14-2023, 04:44 PM
                              • bohaboha
                                Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                by bohaboha
                                Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                anyhow i couldn't t read anything else
                                the backlight is on strong and the screen does not get dark or very dark but no pictures
                                the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                01-02-2025, 08:04 PM
                              • jose6326
                                Samsung s32d850t powers off
                                by jose6326
                                Powers on as normal shows an image then powers off after 10 seconds
                                I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                No blown caps
                                I searched for this model but nothing comes up...
                                11-29-2024, 11:21 PM
