Element E4SFT551 Charred power board
  • jason123
    • Oct 2015
    • 1068
    Hi
    I don't usually acquire ELEMENT TVs, but this one is "Smart TV" 4k, and FREE!
    took it home and found a black section on the power board. Not sure it's worth investing in this TV at all. has anyone had any experience with this TV or Power supply?
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Re: Element E4SFT551 Charred power board
    I think it would be better to find a replacement for the power supply. Even if you replace the burnt items I bet there will be more bad ones that are not visibly damaged.
    Also check the mainboard for visible burnt marks.
    Good luck!
    • R_J
      • 9535
      It might be repairable, hard part would be finding out the component values, but shopjimmy has the power supply for $29.00
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        if board view is available it may be fixable .. how many layers to the board ?
        • jason123
          • Oct 2015
          • 1068
          looks like a single layer board
          • jetadm123
            • 2169
            Resistors shorting like out like that are usually an indication of a more serious problem. Considering they're using CapXon caps that should tell a little about the design/quality of this board. RJ's $29.00 suggestion is a pretty good gamble.
            • jason123
              • Oct 2015
              • 1068
              Just to complicate life, I ordered the correct Power supply board, MP5055-4K1, and the seller accidentally sent me MP5055-4K1C, though the auction photo shows the correct board. I'm attaching a photo of the ad photo (correct board I have) and what I received. It looks like the board I received only has one backlight LED connector, and a couple of differences (jumpers vs. resistors).. does anyone know the differences between these boards? Can I modify the MP5055-4K1C to be MP5055-4K1?
              • jason123
                • Oct 2015
                • 1068
                Hi all.. Replaced the power board and the TV is working great. Thank you for the help!
                • SLK001
                  • May 2014
                  • 264
                  What power supply did you use?
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Did you modify the new board to the old or did you simply replace the old with the new???
