Jvc lt-50e73
+ More Options
Posts
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: Jvc lt-50e73
    Exactly, desoldering flash chip,programming and soldering back. you can also sometimes find flashed chip for your tv on ebay or so
    • mtoivanen
      • Sep 2014
      • 9
      • Finland
      Re: Jvc lt-50e73
      Got myself a programmer, reflashed the firmware and sound works now!
      • cabbansweden
        • Jun 2023
        • Sverige
        Re: Jvc lt-50e73
        are you still active, i hope you can point me to the firmware cause i have same annoying af issue its making me angry no sound output wghat so ever or someone please help , would be so much apreciated if someone cant help, cant find zip file every where jvc not good to not have on website last hope this forum, or else i throw the tv in trash
        • cabbansweden
          • Jun 2023
          • Sverige
          Re: Jvc lt-50e73
          also issue with buttons on remote not controling tv instead turing it off :P maybe a fw rweflash is fixing that steak to
          • lotas
            • Jan 2016
            • 4553
            • Russia
            Re: Jvc lt-50e73
            Do you have a programmer to overwrite spi flash W25Q64?
            • fester
              • May 2017
              • 158
              • Slovakia
              #26
              Re: Jvc lt-50e73
              here it is
              • corrize
                Nikon D800 camera - flash don’t work and capacitor don’t charge
                by corrize
                Hello, I'm stuck in troubleshooting…
                The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                10-01-2022, 10:02 AM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • ekozeko333
                by ekozeko333
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
