Sony KDL-60W630B Issues! Please Help!
  • jdbird613
    • Jul 2018
    • 35
    Re: Sony KDL-60W630B Issues! Please Help!
    If I am able to make my way down into the LED's, I will definitely be contacting you for some more info!
    • nomoresonys
      • 12328
      • U.S.
      A whole lot of times it's going to be bad leds, weakest part of an led tv.
        You should buy LED tester so you can test the LED strings without opening the LCD panel, it will at least tell you if you have open circuit in the LED string or not.
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • delpiero3
          Sony Vaio SVS MBX-261 board failure
          by delpiero3
          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
          Nevertheless, let's say, i don't come as a total beginner.
          I have this old laptop, which suit perfectly my needs, with the...
          10-29-2024, 06:16 AM
        • huj3r
          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
          by huj3r
          Hi there!
          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
          Photo of the situation after the black shadow dissipates:
          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
          > This indicates HFR Communication error. [ HFR Communication...
          08-15-2023, 10:55 AM
