Samsung U60J620DAF Power and Backlights blink
  • MEB
    • Sep 2013
    • 371
    I have this 60" Samsung that is 18 months old. When plugged in to AC, the red power led on the front of the TV AND the backlights flash in sync with each other once every second or so. This will happen indefinitely until AC is removed. I have unplugged the main board from the Power Supply and symptoms repeat as before. I have enclosed a few pictures to start, but will take more later as it is dark outside. Thank you.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung U60J620DAF Power and Backlights blink
    With everything connected see if STD-BY5V is constant or pulsating, also.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8013
      do you see any picture during that flashing spell? What I mean is if the mainboard runs and just the backlights flash?
      • MEB
        • Sep 2013
        • 371
        Andrew F. Ali - Expected to see STB-5V by the connector shown in the upper center of the attached photo, but did find this SB:8V on the power supply board. If it is somehow related, I got 3-5 VDC fluctuating wildly. It didn't match the beat of the power led and backlights but maybe my meter isn't fast enough.
        Mr. CapLeaker - when plugging in to AC and seeing that flashing spell, I saw nothing that resembled picture. But with LEDs disconnected from PS and plugging in to AC, the power LED behaved normally and by turning on and hitting source on the remote, me and my flaslight were able to see the source menus at the top of the screen. The set powered down by itself shortly thereafter.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          SB:8V is the stand by voltage. I do think you have a LED Backlights problem Do you have any experience at all in disassembly of the Panel and removing the fragile glass screen??
          • MEB
            • Sep 2013
            • 371
            Yes, I have done a few, but only up to 46". I guess handling the glass that big and finding a place to put it is probably the hardest part? Any words of wisdom are welcomed.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              A 60 incher is a big job. You would have to get a buddy to help you with this one. I use six (6) suction pads/cups. Three (3) at the top and three (3) at the bottom. Using long wooden broom handles, pass them through three (3) of the suction pads/cups handles and secure them with masking tape at the top and do the same again for the three (3) of the suction pads/cups at the bottom. Then from opposite sides lift together and rest it down on a carpeted floor covered with a bed sheet. This works for me. Luckily I don't get much 60 or 70 inchers to repair.
              • MEB
                • Sep 2013
                • 371
                Sounds like a good plan. How big, I guess diameter are these suction cups? What are they normally used for to help me find them?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  The ones I have are 4-6" in diameter. They are used for lifting sheets of glass. Try e-bay as that is where I got mine from.
                  What voltages are you seeing on the Backlight LED + and - pins with the black DMM probe on the chassis GND.
                  • MEB
                    • Sep 2013
                    • 371
                    Thanks. I will check there.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      • MEB
                        • Sep 2013
                        • 371
                        Thanks for the reply. I am currently away from the TV but will report back after I get home.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8013
                          Turn the backlights waaay down and see if it kinds of remedies the problem.
                          • MEB
                            • Sep 2013
                            • 371
                            Not exactly sure what I am looking for here, but all I can give you are values with the AC plugged in. With the LEDs disconnected from the PS, the TV will power up with remote but not for very long. So plugging in with the LEDs connected gives D+ =160 VDC. With the LEDs disconnected gives D+ =420 VDC. Both when LEDs are connected and disconnected, D- fluctuates around so much I can't really come up with good readings. Let me know if I am not giving you what you need and I can try again.
                              Lift one leg of the diode D9001C or remove it off the board and then check the RESISTANCE in both directions of that diode, report the resistance reading, make sure that you do not touch the probe tips with your hand because I want to make sure it is not showing your body's resistance.
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                Yes. So far you are doing an excellent job.
                                • MEB
                                  • Sep 2013
                                  • 371
                                  Thanks budm, always a pleasure.
                                  Black lead on Cathode - 235.2K ohms
                                  Black on Anode - 0 ohms
                                  Appears to be SF28G. Thanks.
                                    OK, that reading does not make sense if it show 0 Ohms in one of the reading and 235K in another. Are you testing by putting the probes on each end of the diode?
                                    I think you may have the same diode failure like in this thread with the same diode P/N.
                                    https://www.badcaps.net/forum/showth...t=72153&page=2
                                    • MEB
                                      • Sep 2013
                                      • 371
                                      Yes, I repeated the test several times. Digi-Key and Mouser both have the SF28G or would you recommend trying to upgrade? Any suggestions?
                                        I would get a couple of them for either place then, and when you mount it on the board keep the legs long so the body will be 1/4 ~ 1/2 '' above the board to help cooling the diode.
                                        https://www.badcaps.net/forum/showth...t=72153&page=2 the diode did fix the problem on that OP board.
                                        I ask Jason to see if he can ship the extra one to you.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • nathan425
                                          Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                                          by nathan425
                                          Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                                          Symptoms:
                                          • - no power
                                          • - no standby LED
                                          What I've done so far:
                                          - confirmed power supply is OK
                                          -- CN201 #4 showing 5.3V
                                          -- BD207 showing 5.3V
                                          -- removing the cable between the main board and the power board turns on the backlight.
                                          Pushing the power button on results in no change to any of the pins connecting the two boards.
                                          - function assembly appears to be NO GOOD
                                          -- there is no voltage showing on any of...
                                          11-01-2023, 06:34 PM
                                        • hill01
                                          Samsung UE75MU7009TXZG Endless Power Cycle
                                          by hill01
                                          Hi everyone and thanks in advance for any help I might get here
                                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                          Since a few days, the TV won't turn...
                                          11-17-2021, 02:52 PM
