Ua40f7500 samsung tv dark picture
  • aashiknaik
    • Sep 2018
    • 11
    • India
    I m aashik naik from Vadodara,India.
    I m facing problem of dark picture with my SAMSUNG UA40F7500 TV.
    The T con board is BN41-01939B.
    CN 98BN950 0963AL229 DS40892.
    Backlight working.
    Sound ok.
    If room lights are off then can see the dark image and able to select source from menu,all commands visible but too dark.
    Checked T-CON BOARD..
    T-CON input voltage as well as IC input voltages are 12.5 v which is correct.
    Here i have noticed less voltage at V ONE it is +10.2v i think it should be 27to 28v .
    Other voltages are.
    HVADD: 5 V
    AVDD: 10.1V
    HVIN: 10.3V
    VG1 : 9V
    VG2: 4V
    & SO ON
    3.3V is available.
    But all other voltages seems less.
    DC TO DC CONVERTER IC is RT6905B GQW.
    PIN 35 is giving V ONE 10.3 v dc output. which seems less as i told.
    Can anybody tell me that this can be resolved by changing ic ?
    Or anybody can guide what other thing i shall check?
    I bought another T CON board but that's having different ic and is little different.(ic-SM4152LA).With that as i thought the display brightness ok but picture double and color not ok and can't be used as replacement.But here i noticed that
    VONE 27.2V
    HVADD 8.2V
    AVDD 16.5V
    HVIN 12.5V
    VG1 16.3V
    VG2 14.2V
    to me it means bright picture can be achieved by getting these voltages are in this line.
    Request tech masters to help me.
    Snaps of T CON board 3 pics attached if it helps.
    Awaiting for your response,
    AASHIK NAIK
  • aashiknaik
    • Sep 2018
    • 11
    • India
    Re: Ua40f7500 samsung tv dark picture
    I have received IC RT6905 GQW .
    CAN anybody tell me that is there any difference between RT6905B & RT6905 ?
    Hope somebody knows.Pl. give me feedback.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      From what I read in your 1st post you said: " Im facing problem of dark picture with my SAMSUNG UA40F7500 TV.
      Backlight working.
      Sound ok.
      If room lights are off then can see the dark image and able to select source from menu, all commands visible but too dark."
      If the backlight are working and you can't see a picture BUT in a darkened room you can see menu and select etc, then the T-CON Bd. is working.
      This does not maker sense to me. UNLESS the backlights are very dim.
      Could you elaborate on what your symptoms are?
      Try to carry up the Brightness and Contrast settings and also the Backlights setting on the main menu.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4352
        • Italy - Milan
        With those voltages surely tcon is not working properly, i suggest you not to change the IC but inspect why you have an HVIN so low, it feeds current from tcon input supply voltage to the regulators, but between HVIN and VIN can be something wrong, for example a power switch like some i have seen, that switch feeds some panel voltages while VCore for processor and Vcc for memories are always present.
          This how RT6905 is being used, as you can see the HVIN is fed from switch MOSFET to supply 12V to run the IC.
          BTW, can we see the screen shot of what the pictures look like?
          Please also provide the pictures of the whole back side of the TV showing all the boards.
          • aashiknaik
            • Sep 2018
            • 11
            • India
            Thanks for your reply,
            I had tried with brightness control and contrast setting.but not much difference.
            Backlight setting unable to operate.
            • aashiknaik
              • Sep 2018
              • 11
              • India
              Thanks dear Davi.P,
              I have removed IC.so, let me fix new ic and again i will go thro' and come to you.
              But thanks a lot for the prompt reply.
              Will post reply once i fix IC and find why HVIN is low.
              • aashiknaik
                • Sep 2018
                • 11
                • India
                Dear sir,
                Thanks for the prompt reply,
                Actually i didn't expect prompt replies from tech buddies but you all are really the most helping hands or let me say helping minds.Really appreciate all.
                Meanwhile i had removed ic so, let me fix ic and then will study all voltages and then again come with all pics and details to you.
                Thanks a lot again,
                Aashiknaik
                • aashiknaik
                  • Sep 2018
                  • 11
                  • India
                  Dear sir,
                  yes, you are right. MOSFET output comes to 10.43V @ 22u coil shown in RT9605 diagram which you have sent.
                  I have removed IC RT6905 before i show these posts.But it seems that the problem is with MOSFET or surrounding circuit.
                  AT source S it shows 12.6 V but at D it shows 10.43V.
                  At G it does not show any voltage. there is 1 resistor & 1 capacitor in series It doesn't show any voltage at resistor or gate but at capacitor input 12.5 v available.
                  WHAT VOLTAGES WE shall get @ gate as per opinion?
                  I will fix IC once i get 12v at HVIN.
                  Thanks,
                  AashikNaik
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4352
                    • Italy - Milan
                    The voltage on gate terminal has to be negative respect to the drain. So change the mosfet or test it apart. I warn you that when tcon will be fixed you could have a bad surprise because even with a wrong tcon double image it's not normal..
                    • aashiknaik
                      • Sep 2018
                      • 11
                      • India
                      I tried one more t con of same pcb but of different model and got 2 images up and down section.But it was not dark as found in original t con.That T CON is suitable for UA40F6400.A very small capacitor is there between S and opposite terminal of 6 pin MOSFET.
                      The other T CON WHICH is suitable for UA40F6400 Model is giving 12.5v @hvin.
                      I tried to use MOSFET of that T CON but found no voltage at Drain.so, i replaced with original one. With original one i again got 10.43V.
                      Original MOSFET - D5EV. & the other one having MOSFET D52V.
                      How to get this MOSFET? Can i replace the original with the other one?
                      Thanks for your replies
                        So what is the designator of the MOSFET for the swithced HV12V, Q???
                        Can I see the pictures of that area where that MOSFET is?
                        The GATE of that MOSFET should be driven by the RT IC via GD pin as shown in the diagram that you are using as the guide, Q109 is the reference as shown in the diagram.
                        • aashiknaik
                          • Sep 2018
                          • 11
                          • India
                          As i searched for D5 in s-manuals it shows PNP & NPN Digital transistor.
                          The images attached but the IC is removed.
                          • aashiknaik
                            • Sep 2018
                            • 11
                            • India
                            marked what i assumed.
                            As per your post Gate voltages shall be supplied by RT6905 GD point i think first i should fix IC
                            • chrismurphy
                              • May 2014
                              • 251
                              • australia
                              Cut the PWM dimmer wire from the main board
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4352
                                • Italy - Milan
                                I said to you not ot desolder IC!!
                                • aashiknaik
                                  • Sep 2018
                                  • 11
                                  • India
                                  yes, but before i noticed i had already desoldered it. sorry.
                                  Now i will fix it & check again.
                                    09-07-2024, 05:50 AM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • Danstona
                                    LG 65UK6090PUA - picture dark
                                    by Danstona
                                    Was watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
                                    bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
                                    I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal...
                                    03-10-2024, 12:41 PM
