Samsung UE55F6800SB
  • vinceroger69
    • Mar 2012
    • 6714
    #101
    Re: Samsung UE55F6800SB
    the colour test picture looks fine i cant recall seeing this fault in any of the other threads lets hope a more experienced member can advise what they think the issue is.
    • ronhayes
      TV Engineer
      • Mar 2014
      • 458
      Yes hopefully they can !!
      The test card picture i can not see any lines hoping this will be a menu issue or software problem ?
      • ronhayes
        TV Engineer
        • Mar 2014
        • 458
        I am thinking this is maybe a ribbon connection issue ?
        And as these lines are across the the whole screen I think it is the ribbon from main board to T-con.
        The only way for me to find out is to try a replacement one.
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Hi Vince
          At least one thing has come from this i was right and the fault was the T-Con board.
          • vinceroger69
            • Mar 2012
            • 6714
            #105
            yes you was right its hard too fault find some tvs but usually when you disconnect the mainboard from the power supply on a samsung and the backlight comes on and stays on its usually a mainboard fault but i think we have all learnt now to ask people to carry out the tcon removal test too now. It looks a nice tv lets hope you can fully fix it.
            • ronhayes
              TV Engineer
              • Mar 2014
              • 458
              Yes it is a nice Tv hoping it goes well.
              Yes on most of the threads i had seen it pointed to a faulty main board but at least others have another test they can try to test the T-Con. And no harm done as i have a known good new main board that i can sell.
              • megaraider
                • Jul 2015
                • 307
                • Portugal
                #107
                If I'm not mistaken, from the video you posted i recall those blurred vertical blue lines weren't there
                Therefore either you introduced the problem by dis aligning the ribbons or the replacement T-CON board did
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #108
                  in the video ive just re watched the lines are their more sparkly type lines though but certainly there so maybe this is a different issue?
                  https://www.youtube.com/watch?v=QVlZ...ature=youtu.be
                  • ronhayes
                    TV Engineer
                    • Mar 2014
                    • 458
                    Yes it seems they are there but look more sparkly.
                    I have also checked the ribbons and they look correctly seated.
                    • ronhayes
                      TV Engineer
                      • Mar 2014
                      • 458
                      I am wondering may be this is a fault in the power board ?
                      • megaraider
                        • Jul 2015
                        • 307
                        • Portugal
                        #111
                        Yes. Thought they were due to poor feed source (scart).
                        Can you recall if they there before this all problem happened?
                        • megaraider
                          • Jul 2015
                          • 307
                          • Portugal
                          #112
                          Also, to me it they appear to be just (or mainly) blue, and static (as if with memory, i.e. if the image changes they will move).
                          Do you confirm?
                          • ronhayes
                            TV Engineer
                            • Mar 2014
                            • 458
                            No as when i first had set it was always doing the off/on booting but for short while on looked like sparkly' s on screen.
                            I have took a couple more pictures of darker screen and lines are more prominent in these pictures seeing blue and red.
                            I really think this is from P/S board maybe a faulty cap don't think main board as i have tried both main boards.
                            Thinking of changing caps in the power supply .
                            • megaraider
                              • Jul 2015
                              • 307
                              • Portugal
                              #114
                              Thinking of changing caps in the power supply.
                              imo, if they were random and sparkly only, then it might point to the PSU;
                              But they form a distinct vertical path and therefore PSU caps are not the first, neither a likely, approach!
                              Furthermore, with static saturated color test pattern (20181004_122653.jpg) they aren't (much) visible.
                              Therefore it's either the T-CON, the ribbons from the T-CON to the display, or, in the worst case scenario, the display itself.
                                I suspect the replacement T- con because the first wrong T-con you put in did not cause the vertical streaks like you are seeing on the screen right now with the correct board.
                                • megaraider
                                  • Jul 2015
                                  • 307
                                  • Portugal
                                  #116
                                  Nice catch @budm... very assertive
                                  Also comes to my mind that quite often LCD TVs have an option on the secret hidden service menu to set the LCD panel, from a panel list (with Samsung and Sony TVs i've confirmed).
                                  Thus i think you should first check it out
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #117
                                    EDIT ! please ignore this i was looking at the wrong pictures,
                                    in pictures three and four post 75 showing the wrong t con fitted, it still has the sparkly type lines though its a odd fault ive not seen before.
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      Thank you budm,megaraider
                                      When you say check it out do you mean go into this secret hidden menu and try other panel settings?
                                      If so how do i do this ?
                                      And would i set the panel as a 46" to see if picture is clear with the 46 T-Con board ?
                                      Or should i find another T-Con board if possible ?
                                      I have included a picture of both my faulty 55" and the wrong 46" T-Con's as you can see they look identical apart from the numbers on the SDP1209 processor .
                                      Would swopping these processors over maybe repair my faulty T-Con board ?
                                      And is there anyone who could do this ?
                                      • ronhayes
                                        TV Engineer
                                        • Mar 2014
                                        • 458
                                        Morning vince
                                        Yes you are correct pictures three and four do show them but they are the pictures with the faulty 55" T-Con board as taken off my pc screen. But the next two pictures are with the 46" T-Con board as you can see from the explanation given in post 75.
                                        But you did have me going then ha ha.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #120
                                          Morning vince
                                          i blame lack of sleep lol i should have read the post better but lets hope there is a hidden service menu
                                          regarding a possible faulty new t con thats causing this did you manage to message that ebay seller of the repair service and see what his repair service fixes maybe its this issue?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
