Th-p50x50z, no picture, no screen glow, semi-fine SN board
  • BigPete
    • Jul 2012
    • 76
    • New Zealand
    I bought a TH-P50X50 Panasonic plasma TV which had sound but no picture and no error code and no screen glow. The SN board LED was lit green and was humming with no shorts and has the right voltages.
    I thought it was a main board issue so I looked around and managed to pick up the same TV with a cracked screen for cheap, NZ$10.
    I swapped out the main board, no difference.
    Swapped out the PSS board, no difference.
    The TV with the cracked screen had a SN board with a failed buffer IC due to the cracked screen, so i unsoldered it and installed it with the corresponding screen ribbon left unconnected.
    TV fired up fine with a picture on the screen!
    So my thoughts are this:
    I read this post:
    https://www.badcaps.net/forum/showth...ght=c14&page=6
    I figured it could be buffer IC16561 but with no screen glow thought possibly unlikely.
    I figured it could be the IGBT Control chip IC16921?
    I figure the picture data would be coming through but with an un-energized screen it couldn't be seen.
    Service manual for it is below.
    I have parts that can be transferred from one board to another but I'm not sure which parts and would rather not guess as they will be a pain to solder.
    Here's a good picture of it:
    http://assets.shopjimmy.com/media/ca...rhuu-top_3.jpg
    Any help would be appreciated.
  • BigPete
    • Jul 2012
    • 76
    • New Zealand
    Re: Th-p50x50z, no picture, no screen glow, semi-fine SN board
    Did some comparing between the boards and there seems to be an anomaly between the readings of Q16820 between the two boards.
    I'll investigate further.
    • BigPete
      • Jul 2012
      • 76
      • New Zealand
      Made some head way.
      VAD on the working board with the missing buffer IC, the one that has a picture is 100V.
      VAD on the working board that's intact but no picture is 35V.
      I'll do some more investigating.
      • BigPete
        • Jul 2012
        • 76
        • New Zealand
        I think I have figured out the issue but can't figure out why the problem exists.
        The voltages between the two boards are the same when using TPVFG as the earth.
        The problem is that there is a voltage difference between chassis earth and TPVFG.
        Can someone read the service manual to point me in the right direction please?
        TIA
        • BigPete
          • Jul 2012
          • 76
          • New Zealand
          I'm not sure if the voltage difference is because the panel is energized on one and not the other.
          The other thing I noticed was that pin 5, the drain pin of IC16784 (MIP3910), has a fluctuating voltage on the working board of between 180 and 190V and the other board has a steady voltage of about 188V.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • TheDando
            MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
            by TheDando
            Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
            10-28-2024, 06:59 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • jean luc ferre
            acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
            by jean luc ferre
            on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
            i tried the hard reset, cmos reset, changing the ram without results.
            in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
            The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
            but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
            Yesterday, 03:54 PM
          • mrtek
            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
            by mrtek
            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
            11-26-2024, 09:58 AM
