LG 55uf7787 stuck on logo
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Busy day today Got another telly in and this one is going to be a tough nut to crack: very big, very new, no info on it....mission impossible.
    LG junker's stuck on logo...1000 euros worth of TV only to have it do THIS after 2 years...that's enough to make you want to attack it with a baseball bat. Makes ME angry, I can imagine what the chaps felt like...
    Haven't taken it apart yet just because I haven't got the space, but I imagine that would be useless outside being able to provide some of you helpful chaps with some model numbers and stuff, since I imagine nobody can spare a service manual or a dump for this thing.....they haven't "leaked" yet, with it being so new. I HOPE I can read and backup the EEPROM just in case...
    just so I can say I at least did SOMETHING to it
    The guy said he turned it off whilst it was attempting a software update or something, so that might be one of the causes...or the board simply crapped out...
    Wattevah...
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Re: LG 55uf7787 stuck on logo
    Mainboard has gone bad. Try resetting the eeproms, or if you have the right tools use a dump for the flash memory. If any of these do not work you have to replace the mainboard.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      I figured...POS Haven't opened it up yet to see what's in there, since it's this big behemoth and I've got the table occupied ATM...
      Wattevah...
      • CapLeaker
        Leaking Member
        • 8178
        Freeze the EEPROM with a can of air upside down, then turn the TV on.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          I'm inside this telly now and I'll be honest: I cannot find an EEPROM chip...either I'm not seeing it or it loads everything off the flash...
          EDIT: I'm about to try something rather daring: flash it via RS232...the first step is to actually see if it even connects with it being stuck on the logo and all. I'll try making myself an adapter cable, based on THIS, which is a different model, but hopefully the pinout hasn't changed. TX to RX and RX to TX, into the CH341 programmer set as COMx, putty and attempt a connection. If done right, based on another source, I should see Mstar show up in the console window....if I'm lucky to even make it that far, I grabbed a firmware file from LG for this model and I SHOULD send that over to it by typing SWUZ....what could possibly go wrong ?
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Unfortunately no, my idea didn't work: there's no response whatsoever. Either the pinout of the jack is not correct (though I tried flipping TX and RX around), the interface is not RS232 or the TV simply doesn't respond because it's dead.
            There's another header on the board clearly labeled RS232, but good luck finding the pinout for it. I also see a MAX IC on there which to my recollection is a level shifter, so it could be that it's expecting a "purely" serial interface, like on a motherboard, on that jack. Since I'm using it with a USB adapter (the CH341), it could be that it's not at the right level and I'd need to use that header with the CH341...I dunno
            Wattevah...
              You'll probably find that small white connector has a serial port on it. You can use a scope to see if there's any activity when you power it on.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Don't have a scope sadly...I managed to find the GND pin though, so I COULD wing it by trying different combinations, but there's 4 pins. 1 more than your regular RS232, so I'm not sure what the extra one does: TX, RX, GND, ?...something could blow if I just randomly connect them. I'll try the jack once again, this time with an older PC with an actual serial port, just to rule it out...getting win 7 installed on the thing right now
                Wattevah...
                  Yeah, you'd need a scope to do this. Sorry.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    I made another discovery: Putty refuses to run on Win XP and I couldn't get win 7 on the junker with the COM port, but my theory was correct: using that hyperterminal thing win XP has, I DO get some response from the TV, which is:
                    MIU0-DQS-OK
                    MIU1-DQS-OK
                    XLC_
                    So there may be something there...
                    Wattevah...
                      That's the RAM training. DQS is the DataN write strobe, so byte writes can be masked.
                      Looks like it passes that at boot, but everything subsequent fails.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Dead CPU or something ? Either way it's trash - I'm just curios to learn more in-depth
                        Wattevah...
                          Could be a BGA failure but I expect after RAM training it will try and load the Linux kernel.
                          That isn't happening for one reason or another, bad bootloader would be my guess, unless the kernel's first executable page is trash, but usually u-boot or whatever these run will decompress the kernel first.
                          Odd, in any case.
                          • Diah
                            • Feb 2013
                            • 6376
                            need to send command via IR "IN_STOP" this will reset the eeprom to factory condition
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              How would one go about doing that ?
                              Wattevah...
                              • ducky29
                                • Dec 2015
                                • 370
                                • Europe
                                You need to have the service remote in order to do that.
                                  LG factory remote. Available on eBay.
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    I reckoned....I have obsessed with this several times now, but too bad there isn't a way to emulate all these remotes. The prices are way up there apparently.
                                    EDIT: actually I think there's apps that do this with the IR blaster of a phone....I have a HTC lying around that would do nicely. I can accept having 10 apps than 10 remotes I remember I have done this before with a Samsung which had a locked service menu and wouldn't let me change some panel options. It was as easy as downloading the app, pointing the thing at the TV and I was in.
                                    Wattevah...
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      this thread maybe worth a read the software post 19
                                      https://www.badcaps.net/forum/showth...service+remote
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        Following the information HERE, which is very handy, is there an app which functions like a programmable remote and allows you to enter those codes in it like with a Logitech Harmony ? I'm inclined to get myself a Harmony, despite having this discussion before and someone suggesting they're rather sucky and not worth it...I'd get it just for the service codes. I've got them for LG now, I wonder if there are any for Samsung too...
                                        Wattevah...
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • justice171
                                          JVC LT-50N795 Stuck on Wisdom Share Logo
                                          by justice171
                                          I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                                          It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                                          Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                                          Thanks in advance!
                                          11-04-2024, 02:55 AM
                                        • mr.Data
                                          Macbook A1990 stuck on logo
                                          by mr.Data
                                          This Macbook Pro 2018 boots up and then gets stuck on the logo.
                                          All the normal methods of resetting this Macbook have been tried but do not work.
                                          I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                                          Any help would be greatly appriciated....
                                          04-18-2024, 11:51 PM
                                        • platinumsteel
                                          Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                          by platinumsteel
                                          Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                          03-18-2024, 05:16 PM
