Sanyo DP42848 colored vertical lines
  • x_orange90_x
    • May 2015
    • 765
    I picked up a DP42848 the other day and to my surprise it wasn't cracked. Instead however it works but has colored vertical lines across the screen, and they also go over top of the OSD. I tried tapping the back of the TV but they did not change or go away. The do however change color and get thicker/thinner if I twist the TV a little bit. Attached is a picture of the lines. Is this a T-CON issue, panel issue, or possibly just dirty/loose LVDS cables? I haven't had time to open it up yet to check the latter.
  • R_J
    • 9628
    Re: Sanyo DP42848 colored vertical lines
    Check the t-con cables and lvds cable.
    If the t-con is located at the bottom of the tv, I would suspect water damage to the panel board, The board the t-con flat cables connect to. That would be my guess
    • x_orange90_x
      • May 2015
      • 765
      I will check these, thanks!
      • x_orange90_x
        • May 2015
        • 765
        I finally got time to check out the TV today. I cleaned and reseated the ribbons going from the T-CON to the panel and saw no improvement. While in there I spotted a bad cap on the main video board. I replaced it even though I knew it wasn't the culprit, simply because it needed to be replaced anyways.
        Is it even possible for the T-CON to cause these kind of vertical lines? Or is there likely something wrong with the panel itself? As I mentioned before, twisting the screen changes the size and color of the lines.
        • vinceroger69
          • Mar 2012
          • 6714
          if twisting the screen changes the lines etc i would suspect bad tab bonds like r_j asks is the t con on the top or bottom of the tv
          • x_orange90_x
            • May 2015
            • 765
            The T-CON is at the top.
            • vinceroger69
              • Mar 2012
              • 6714
              i would wait too see what others think first but then you may have too strip the tv down a bit and put some pressure on the tab bonds and see if they go away its a bit odd the lines are all across the screen though the issues i have seen its just been one section
              • x_orange90_x
                • May 2015
                • 765
                I know, it's very odd. Every picture I've seen when searching "vertical colored lines" are all screens filled with lines all the way across, or just one half filled. This is an older TV though, so perhaps the tabs are somehow uniformly coming loose. Hopefully someone else can jump in with suggestions.
                • budwich
                  • Jul 2015
                  • 3097
                  disconnect one at a time, the tcon to panel cables and see what happens. that may give you a clue about where the problem lies.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Originally posted by budwich
                    disconnect one at a time, the tcon to panel cables and see what happens. That may give you a clue about where the problem lies.
                    +10
                    • Stanley1843
                      by Stanley1843
                      06-29-2024, 11:54 AM
                    • pni
                      LG 49uf695v vertical coloured lines
                      by pni
                      Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                      11-14-2025, 03:15 AM
                    • Falki
                      Colorful LCD Vertical Lines on Samsung ue55es8090
                      by Falki
                      Hello there, ive recently found an older 55inch Samsung SmartTV.
                      A similar issue has been posted as well but also with no actual response ...
                      08-12-2025, 04:19 AM
                    • visionbluedemon
                      Help. Sony kd-65x85dj vertical lines
                      by visionbluedemon
                      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                      tried blocking LC lines too, but same results
                      is it lcd panel issue or tcon board issue?...
                      07-25-2025, 04:56 AM
                    • gpo23
                      Sony KDL-40V3000 - Vertical lines
                      by gpo23
                      i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                      With the new t-con the color are good but there are vertical lines on all the screen :
                      I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                      Is there a way to fix the vertical lines on the new t-con ?
                      Thank you for your help
                      gpo23...
                      10-04-2023, 09:11 AM
