my SHARP LC-40LE810UN has issue help needed to find and fix.
+ More Options
Posts
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4286
    • Italy - Milan
    Re: my SHARP LC-40LE810UN has issue help needed to find and fix.
    If you're happy to experiment then you can simply shortcircuit the secondary side of the optocoupler and keep the tv in test, if it works flawlessly then you found the bad component.
    • nilesh
      • Jul 2016
      • 34
      • 86994392471
      thanks for suggestion, i thought earlier for that but wasn't sure about ,
      tomorrow i will get parts and will check. thanks again
      this
      • nilesh
        • Jul 2016
        • 34
        • 86994392471
        sorry for delayed response,
        badly stuck in job, as well i am in canada so very backword country
        PC123 optocoupler not available , so order online its $2 part but no choice ...
        once i fix i will update ..seems bit be bit delay !!
        this
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4286
          • Italy - Milan
          EL817 is the same...
          • nilesh
            • Jul 2016
            • 34
            • 86994392471
            Thank you Davi , help apriciated,
            this
            • johannesstroh
              • Sep 2018
              • Österreich
              #26
              As mentioned here instead of replacing the opto u can simply solder a 47k resistor in parallel to R7019, which is in series to the opto on the primary side and get the opto working again
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4286
                • Italy - Milan
                #27
                But you can find an optoisolator in every modern power supply like old lcd monitors that you can find on the dumpster...
                • nilesh
                  • Jul 2016
                  • 34
                  • 86994392471
                  #28
                  Thank you for option, apriciated
                  i received optocoupler last night , PC123 by sharp
                  in 2 days i will replace and check .
                  hope for best , thanks again .
                  this
                  • nilesh
                    • Jul 2016
                    • 34
                    • 86994392471
                    #29
                    yes Davi,
                    you are right , previously i throw so many , but when you exactly need that time you don't have, in North america is consumer idology ,to find PCB part or fix/repair PCB is like fixing setellite , 99% people says throw TV or best case buy used PSU board ebay , only 3% case some shops or hobbiest like me try and learn before spent money on new TV . here they convience people to throw stuff and buy as well push them to forget to read or self learning skill top of that get access to parts harder and harder etc and make them zombie asap.
                    thanks again.
                    this
                    • nilesh
                      • Jul 2016
                      • 34
                      • 86994392471
                      #30
                      stuck with unfortunate issue,
                      the New part i got seems to be bad,
                      i chage optocouplar , and tv doesen't start at all
                      than i put back older one and tv start right away, it tend to believe me that that new part may bad, now quick option is only left to use 47K resister. will be update soon , thanks
                      this
                      • nilesh
                        • Jul 2016
                        • 34
                        • 86994392471
                        #31
                        will be update soon .
                        BTW my PSU board i can locate R7020 not R7019 ...so need to confirm before i solder resistor !! pic attached !!
                        thanks in advance. help apriciated
                        this
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4286
                          • Italy - Milan
                          #32
                          how do you have mounted the optocoupler?? it has a mark point that identifies pin 1,
                          this must be connected to the HOT (primary) side!
                          • nilesh
                            • Jul 2016
                            • 34
                            • 86994392471
                            #33
                            Thank you Davi for precautionary alert !! apriciated
                            yes , previously i solder some IC so i know there dot to count pin 1
                            although i always take pic. before i unmount older one, i didn't do any mistake on this one too, but seems its just bad piece like my bad luck
                            but not big deal i already order another , may be 3-5 days i have it .
                            thanks
                            this
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4286
                              • Italy - Milan
                              #34
                              I say this for you, read again my post #21.... (!)
                              • budwich
                                • Jul 2015
                                • 3097
                                that's quite funny... :-) and here I thought up here in ottawa that we were in the backwaters of canada / ontario and that toronto was the center of the universe. Even finding simple parts is difficult.... now I don't feel so bad having to order elsewhere beyond the "border".
                                Hope you are successful... and save another set from the dump.
                                • nilesh
                                  • Jul 2016
                                  • 34
                                  • 86994392471
                                  #36
                                  you mean direct jumper (short) on secondory between Emitter and Collector ??
                                  this
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4286
                                    • Italy - Milan
                                    #37
                                    Of course.
                                    • nilesh
                                      • Jul 2016
                                      • 34
                                      • 86994392471
                                      #38
                                      Of course.
                                      thanks , tonight or tomorrow morning i will
                                      if it works fine , is it ok to leave shorted for few hours till 2-3 days ?? till i get new parts !!
                                      just for curiosity what could serious damage to keep running with jumperd secondory side ??
                                      thanks
                                      this
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4286
                                        • Italy - Milan
                                        #39
                                        You don't have to worry about because the function it's used only when mains disappear, but even if it will do, no serious damage will happen.
                                        • nilesh
                                          • Jul 2016
                                          • 34
                                          • 86994392471
                                          #40
                                          thanks
                                          this
                                          • claytongarcia
                                            Issue with Sharp LC-42SB45U
                                            by claytongarcia
                                            I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
                                            Has anyone dealt with this issue before?​
                                            03-10-2025, 07:27 PM
                                          • Asraf Atb
                                            by Asraf Atb
                                            01-27-2025, 05:02 PM
                                          • leorivers
                                            Issue with Sharp LC-47SB57UT
                                            by leorivers
                                            I bought Sharp LC-47SB57UT 6 years ago. I had to have a vhf antenna to pick up one local station(koco channel 5 OKC). It has worked great up until a week ago. Sometimes I couldn't get channel 5, now I can't receive it at all. I can hook up a digital convertor box I have from another tv and can receive channel 5.
                                            I think the antenna and cable is ok. I doubt that this would be the tuner board or possibly something else.
                                            Any ideas where I should start?​
                                            10-24-2024, 03:11 AM
                                          • ant3202
                                            Help Needed to Find Replacement for the IC Chip - CY1341A
                                            by ant3202
                                            Hi All
                                            Had tried using google lens but not much info was provided.
                                            Appreciate if you can help identify this component.
                                            IC Seems to be SOT-23.
                                            Thank You...
                                            05-15-2025, 08:45 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
