Service Menu for 50LN5750
  • neilc6
    • Nov 2015
    • 1550
    I was repairing the backlight on a 42LN5700 and forgot to remove the screw at the component connectors. I ended up pulling out the terminal block. I was able to unsolder the pins, push them back in and resoldered the block. Quick test and everything was ok but when I buttoned everything back, the TV wasn't booting (no DRV_ON signal) and front LED was dim.
    I had a main board from a 50LN5750 and it appeared to be an identical match other than part number. I popped it in and TV works fine. Though I renamed the TV in the menu, the LG remote app still detects it as the 50LN.
    Looked for online instructions to get into service mode and didn't work. Tried pressing both OK on side button and remote simultaneously and MENU button as well.
    Maybe it's a sign I shouldn't mess with it since it is working. Bonus is that it will now support a magic remote.
  • neilc6
    • Nov 2015
    • 1550
    Re: Service Menu for 50LN5750
    I am going to answer my own question here. To get into the LG service menu, you can download an app if your phone has an IR blaster or you can buy a service remote (Aliexpress, Ebay). Buttons are IN START, ADJ, and IN STOP (performs factory reset). Use 0413 as a password or google for other possibilities.
    Looking at the options in the ADJ menu shows an option for default backlight for ECO mode (70) and a 75% Backlight option. Wondering if 75% is an option to reduce the maximum backlight or to set the default backlight to 75%. Don't want to tinker too much with service menu options.
      It looks to me it the backlights will be at 75% if you set the TV to ECO (Economy) mode in the OSD User setup menu, but if you set to I.E. VIVID mode it will probably drive the backlights at 100%.
      • neilc6
        • Nov 2015
        • 1550
        They were 2 separate options. One is likely the default backlight level for eco mode, The other just says 75% backlight. There is a youtube video but the backlight options are slightly different.
          I wonder if that is updated FW that LG puts out to reduce the backlight so the maximum drive will be at 75% (100 on the User menu).
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • intercepter
            JVC LT-32CA120 service menu
            by intercepter
            I have JVC LT-32CA120
            Board:Vestel 17MB171
            I need rotate screen.It is possible in service menu and how to enter service menu?
            Thanks.
            12-10-2024, 10:29 AM
          • sohail5307
            I need how to open this Dell service menu option in dell latitude e6420
            by sohail5307
            I need to open service menu of Dell laptops like image in attachment
            Ignore my English
            I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
            01-13-2023, 05:56 AM
          • Storyteller12
            QN55Q60R Service Menu Panel Help
            by Storyteller12
            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
            01-13-2024, 01:57 PM
          • Daniel Valdez
            Samsung UN70RU7100K halfway bricked after messing with service menu
            by Daniel Valdez
            Dear All,
            FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
            12-06-2024, 06:56 PM
