Sony xbr55x850d & 7 Blinks
  • itelite
    • Aug 2016
    • 124
    Had a 4K Sony xbr55x850d come in with 7 blinks after about 1 minute of power on.
    Closest service manual i can find is for XBR-49X837C which is an older model, but looks pretty similar. 7 blinks is listed as a temperature error possibly related to IC1400. This is a 6 pin chip marked U9AN. Not able to find a data sheet for this chip. Has 3.3V, Ground, (2 other pins grounded), and 2 likely data/clock lines that are both at 0.5V. I would expect a 3.3v 4.7k(or so)pull up for i2c. Seems likely to be i2c but no clock or data on the lines and that voltage seems very low. 3.6K to ground on those lines.
    Anyone happen to have the service manual for this? the XBR-49X837C is not at all the correct board layout, and given the differences im not hugely confident that the 7 blink error code is the same on both models.
    Any thoughts on the above ramble is appreciated
  • itelite
    • Aug 2016
    • 124
    Re: Sony xbr55x850d & 7 Blinks
    Well culprit has been found. Another HDMI switcher. What did i do to deserve this ha.
    3.3V supply shorted (20 ohms) to ground through IC. Removed IC, TV boots up, of course no HDMI inputs.
    Now time to source this chip. ugg....
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Good work on finding the cause of this fault.
      • charlie555
        • Feb 2018
        • 76
        • usa
        900e 7 blinks which ic please?
        • itelite
          • Aug 2016
          • 124
          In my case it was an HDMI switch IC. Look at the traces coming off the HDMI ports, follow them back to a chip. This is the HDMI chip. Google the part number to confirm it is indeed and HDMI switch IC.
          • Nick's Tvs
            • Jan 2014
            • 621
            For the 900E models a 7 blink = Over temperature protection [TEMP_ERR]
            <B/P> Temp. sensor I2C No ACK [TEMP_ERR]
            The 900E model main board does not have an HDMI switch IC like the 850D does, goes direct to the main processor chip. If your main processor chip is the issue, might as well replace the board.
            • Bruce_9119
              • Nov 2016
              • Taiwan
              SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
              EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402. Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:
              this is 65X850D_7blink_codes show ...may be can save
                The TV we are trying is fixed is not CRT TV.
                • visionbluedemon
                  Help. Sony kd-65x85dj vertical lines
                  by visionbluedemon
                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                  tried blocking LC lines too, but same results
                  is it lcd panel issue or tcon board issue?...
                  07-25-2025, 04:56 AM
                • ggil44
                  Sony XBR-65X750D Horizontal lines bottom of screen
                  by ggil44
                  Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                  05-30-2023, 07:51 PM
                • Chrissygizmo
                  Sony KD-55XG9505 lines on screen problem
                  by Chrissygizmo
                  Hello again everyone,
                  This is my latest mission, to try getting this Sony tv back to normal working order…
                  I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                  02-19-2025, 11:31 AM
                • noisykid
                  Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                  by noisykid
                  5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                  12-30-2024, 07:15 PM
                • matwan
                  Sony XR-55X90J 5 blinks
                  by matwan
                  I have problem with SONY 55X90J. After several check status is as below;
                  1. Running power board as stand alone:
                  TCON_12V =~ 12.6V
                  EVDD V On Max 24V= 19V.
                  2.
                  Running power board with TCON as stand alone:
                  Effect as below, attched.
                  3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                  "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                  Best regards....
                  09-28-2025, 04:26 AM
