LG 55LW5600 No Video No Sound
    • 12323
    • U.S.
    #41
    Re: LG 55LW5600 No Video No Sound
    List the panel number of the tv and we'll see what we can figure out.
    • engyshe
      • Jan 2015
      • 14
      Tv model is 47LW5700
      LA12C is assembly number
      main board EAX64344102(1)
        • 12323
        • U.S.
        #43
        Panel number should be on the back metal chassis on a sticker.
        • engyshe
          • Jan 2015
          • 14
          I see. I will look when I get home. None of my pictures cought that detail.
          I have been reading service and training manuals, but could not figure out how to determine if backlite diodes are fine if there is no mainboard 3.3V to supply TCON board and other controls. Unless it is this 220ohm to ground test. In that case, should I disconnect cables between main and TCON board (LVDS/power)?
          • engyshe
            • Jan 2015
            • 14
            Here is the panel number LC470EUF (SD) (F2)
              • 12323
              • U.S.
              #46
              This appears to be a good list of substitute mainboards for your 47 LW5700, might need to put LG in front of them if searching:
              EBR73360903
              EBR74261202
              EBR74261207
              EBT61409804
              EBT61410005
              EBT61804804
              EBT61804905
              EBT61804907
              EBT61804912
              EBT61804913
                • 12323
                • U.S.
                #47
                Your best bet might be one of the repair services, I would try to get one that has a good rep. and offers at least a 6 month guarantee: https://www.ebay.com/sch/i.html?_fro...10008&_sacat=0
                • engyshe
                  • Jan 2015
                  • 14
                  I will contact repair shops and send my board out. I will verify that panel LEDS are fine first and then do that. Thank you for the help and your time. Cheers
                  • PeterKiryluk
                    • Feb 2013
                    • 4
                    Just had a TV come in exactly as stated above No backlight, button turns from red to white stays white nothing showing on picture. Main board needed to be reheated. LG 55LW5600
                    • wylde
                      • Sep 2025
                      • 6
                      • FR
                      #50
                      Symptoms point to main board problem. Checking all the voltages and resistances is hard to understand for most non-electronics guys like me - best information that I found was this. If the LED lights / screen image is not coming up the power board is not necessarily the problem, if you have the power board transforming voltages that are readable on your outputs than it is probably ok even if they are not exactly to spec- the main board actually needs to signal the power board to supply voltage to backlight circuit.
                      Reflow repair on the mainboard is probably the best option- if you are doing it at home with a heat gun reduce the size of the tip as best you can, even with a tin can (wrap it around to make the tip the diameter of a finger) just do a test before attempting on the board by putting some solder on an old board/wood scrap and applying the heat until it melts - if you count the number of seconds it takes you will have a rough gauge as to how long to apply heat to your chip to melt the hidden solder .
                      You will need to remove the heatsinks (hardest part)that are on the chips. Try and protect surrounding area with alu tape/carboard etc to isolate the chip you are heating. As you focus the heat on the chip try not to move it or any other components - keep the blowing speed of your heat gun to a a minimum - there are tons of surrounding resistors etc that are tiny so be careful not to bump them or blow them out.
                      here is another thread that outlines similar problem to yours. https://www.badcaps.net/forum/troubl...-s-help-please
                      • soeren
                        A2442 - No sound over internal speakers and no video playback
                        by soeren
                        I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                        All happened after the battery ran out of power overall several days when I was on vacation.
                        I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                        07-26-2024, 01:24 AM
                      • JRade
                        Audio video receiver KENWood KR-V990D,no sound
                        by JRade
                        When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                        The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                        I replaced the capacitor C303/0.047F, nothing changes.
                        I'm asking for help, what should I do next?
                        Thanks in advance!...
                        08-05-2025, 10:23 PM
                      • FrancescoV
                        Onkyo HT-R390 no sound output, video output ok
                        by FrancescoV
                        Good morning everyone,
                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                        The firmware reported is the following:
                        M:1.00/11107BLP
                        D:?.??/????????
                        O:1.00/11107AL
                        The DSP firmware given the question marks seems corrupt.
                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                        05-11-2025, 02:59 AM
                      • Audeze
                        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                        by Audeze
                        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                        Does...
                        10-06-2024, 08:54 PM
                        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                        09-12-2024, 02:00 PM
