LED chips for backlight board?
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi im trying to do some trail and error trying to repair a led tv backlight board that had 5 bad leds
    i removed the led chips and would like to buy replacment led chips
    ..not sure what to look for when buying...ive seen some 6v ones on ebay for led tvs... the chips have 2 pads on bottom one larger than the other and are about 3x3mm size..very small
    just looking for something generic that would work with most backlight boards....doesnt have to be exact oem replacment..just something that will function
    what specs would i need to be looking for? voltage? watts? etc etc
  • shelby5041
    • Feb 2009
    • 1505
    Re: LED chips for backlight board?
    pe board is not
    • shelby5041
      • Feb 2009
      • 1505
      tech propblems with pc..i hope board is fixable
      • Wilderone
        • May 2018
        • 76
        Have you got a pic of the LED? it's difficult to see from your pictures.
        Do you have a backlight tester to check the voltage of the LED diode or strip divided by number of LED's?
        You will need to know the voltage.
        To find the correct LED you will need to measure as accurately as possible the width & length ie; 2.8mm x 2.8mm would be a (2828) type, or 2.8m x 3.5mm would be (2835) type so on & so forth.
        Secondly check the bottom pads against the ones you are buying they should be identical.
        Thirdly the top of the LED will have some variation but match as close as possible to the ones you have.
        Here are some examples of ones I purchase, they are very cheap so I usually buy a variety to keep in stock.
        https://m.aliexpress.com/item/324738...ddresstype=600
        http://s.aliexpress.com/ri6R3Eja?fro...y to Clipboard
        http://s.aliexpress.com/JJZbyIjY?fro...y to Clipboard
        With the snapped strip I would scratch some of the coating off & jumper together with wire.
        • shelby5041
          • Feb 2009
          • 1505
          Thank you...yes they r super cheap...so you recommend those 3 sizes?
          Not sure what i have ..but ill look on ebay for those
          Aliexpress shipping costs too high to usa
          What about voltages?
          Are the smaller ones 3v and the parger ones 6v?
          • shelby5041
            • Feb 2009
            • 1505
            And am i looking for cold white?
            Warm white?
            • shelby5041
              • Feb 2009
              • 1505
              Ill try scratching..
              • Wilderone
                • May 2018
                • 76
                Yes those 3 are common, you will see the last link is the 6v.
                Voltages are not size dependant.
                As for the warmth, I can usually tell by eye when I light up the panel with my backlight tester, I find if it's a blueish tint it's cool white & if white light it's warm.
                You should really invest in a backlight tester;
                This is the best one;
                https://m.ebay.com/itm/LED-Backlight...from=R40&rt=nc
                • shelby5041
                  • Feb 2009
                  • 1505
                  Ill research aliexpress..shipping free?
                  So u recommend
                  2828
                  2835
                  3535
                  What about 3030
                  • shelby5041
                    • Feb 2009
                    • 1505
                    Thats too much.for tester...can you recommend a cheap version....i dont need fancy...just need cheap
                    • shelby5041
                      • Feb 2009
                      • 1505
                      Most led tvs ive taken apart are bluish not warm color
                      • Wilderone
                        • May 2018
                        • 76
                        2 x AA batteries lol
                        • shelby5041
                          • Feb 2009
                          • 1505
                          Oh that easy lol...i have a multi regulated ac adapter incan use..it has 3v 5v 6v 9v settings
                          • Wilderone
                            • May 2018
                            • 76
                            So u recommend
                            2828
                            2835
                            3535
                            What about 3030
                            Yes shipping is free on AliExpress unless you want Expedited.
                            I recommend measuring the ones you have.
                            • shelby5041
                              • Feb 2009
                              • 1505
                              thanks i just bought some 2828 and 2835 on ali express and bought 3535 on ebay
                              is 3030 common or not so much?
                              • shelby5041
                                • Feb 2009
                                • 1505
                                how do i know if the led i have are 3v or 6v?
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  i guess if i shoot 3v into them and they dont light up but with 6v they do then they would be 6v
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    i think they are 3v because when i powered on the board only 3 lights out of 8 lit up and it showed like 8.8v...and then shut off..i would imagine the voltage is variable ? so if the other lights were good the voltage would have been 24v or so?
                                    other question is some led tvs have leds in the hundreds..i would iimagine these are lower voltage leds? i cant imagine them being 3v if there are hundreds of them....dont think you would have 300v going to led strip??? or am i wrong?
                                      You need to find out if the big solder pad is Anode or Cathode, it is important for heatsinking of the LED.
                                      • Wilderone
                                        • May 2018
                                        • 76
                                        Originally posted by budm
                                        you need to find out if the big solder pad is anode or cathode, it is important for heatsinking of the led.
                                        +10
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
