Searching for LED strip
  • Wilderone
    • May 2018
    • 76
    Viano LEDTV60FHD.
    Strip has 124 LED's (4014 Type) 662mm long 5mm wide on Aluminum backing.
    94V-0 E349376 HY-A1. 1660001.40030R.3104 20141204
    See attached photos.
    I have searched using the numbers on strip but nothing, if you have or know where I can get one of these please let me know.
    Strip is damaged so needs replacing.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Searching for LED strip
    what lcd panel is used in the tv?
    • Wilderone
      • May 2018
      • 76
      T600LHW15180394
      Model NO-902-L03-600H
      Produel NO-LC600DUK-SGE1
      Here's the panel sticker;
      • Diah
        • Feb 2013
        • 6614
        Originally posted by Wilderone
        Viano LEDTV60FHD.
        from the photos i can tell yours LED on this strip are LED Modul 7030 6 Volts current 260 mA
        see this post where i bought before 100 pieces
        https://www.badcaps.net/forum/showpo...95&postcount=1
        • Wilderone
          • May 2018
          • 76
          No they are 4014 Type 3v & the strip cannot be repaired otherwise I would do so.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            is there a reason that the strip can not be repaired?
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            • Wilderone
              • May 2018
              • 76
              Tracks a burnt in between the LED's, given the lack of area to work with 2mm I have tried but not able to repair.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                i couldn't see the damage in the pics.
                i will look through my parts and check if i have a strip.
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  no luck, but i will keep an eye open in case i come across one of these sets in the near future.
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • adelage
                    220v Led strip flickering
                    by adelage
                    Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                    I know that the best solution would be to get a voltage...
                    11-03-2024, 09:49 AM
                  • benareeno
                    Adjustable dc power supply and tcl led strip
                    by benareeno
                    I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                    I have an adjustable dc power supply and was trying around 9 volts.
                    I have a pic of a single diode...where to put pos and neg terminals to light it up?
                    Pic of middle of strip..is this where i light the entire strip?
                    And pic of end...or does this light the entire strip?
                    Where to put pos and neg for single diode..multiple diodes and the entire...
                    07-11-2021, 02:31 PM
                  • mikey5791
                    Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                    by mikey5791
                    Got this working ips led monitor by the brand of
                    Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                    Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                    09-04-2023, 03:50 AM
                  • Bartoloni
                    Searching info of this PD controller: PS8743B (in a Toshiba Satellite PRO )
                    by Bartoloni
                    the laptop is starting ONLY if a usb drive (or a mouse) is connected on the Type-c port.. leaving it empty hangs startup on DynaBook BIOS LOGO (never seen something like this)
                    searching for the VCC pin . .just to disable it without removing the chip.
                    08-24-2024, 08:41 AM
