Samsung 50 inch Plasma PS50B430 - Vertical lines - Help please
  • Ken Laszlo
    • Sep 2015
    • 28
    Hi everyone
    I'm trying to repair my Samsung 50 inch plasma set, that has a pattern of one (or sometimes two) flickering vertical lines across the entire screen.
    Note that this is intermittent - Sometimes the fault disappears completely and the set operates normally - Of late, though, the fault appears more often than not. Yesterday the patterns of lines was always there and has become enough of an annoyance to demand a fix or replacement.
    What I've done so far.
    Cleaned all the connectors with alcohol and reseated them all. It didn't help.
    Pressed/wiggled many connectors and boards to see if the fault goes or changes in some way to try to track down the fault. It didn't help. I couldn't identify anything.
    I especially checked the cabling and connectors between the main board (bottom right) and the control board in the centre. Nothing changed though.
    Could any help me further with this, please?
    Thank you
    Ken
    I attach a few useful photos of the fault, the inside of the unit and the unit's specs.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung 50 inch Plasma PS50B430 - Vertical lines - Help please
    That appears to be a Main Bd issue. Look for cold solder joints and reflow them.
    • Ken Laszlo
      • Sep 2015
      • 28
      Hi Andrew
      Thank you for your reply and advice.
      I'll remove the main board and check it over - I'll report back.
      Ken
      • R_J
        • 9557
        Have you tried going into the service menu, pdp option sub menu, and access the Pattern select submenu, if the patterns or ok it is likely the fault is on the main.
        I'm not 100% sure but you may be able to run the autogen on this logic board with the main disconnected.
        • Ken Laszlo
          • Sep 2015
          • 28
          Thank you for your advice, R_J - Yes.
          I searched around on the net and found this video detailing just that!
          https://www.youtube.com/watch?v=JjrwTZC5nVg
          Running the patterns (with the main board disconnected) still showed the exact same line problem.
          Would this lead me (us) to suspect the small logic board is faulty perhaps?
          I've cleaned and reseated all the cables and don't suspect any are bad from visual inspection.
          No amount of wiggling or flexing of the logic board or cables (in an attempt to check for loose connections or dry joints) changes anything - The fault is always there.
          Thank you
          Ken
          • R_J
            • 9557
            About the only way you would see where the problem is coming from is with a scope, without a scope you would need to sub out the boards, it is likely control board or Ysus.
            • Ken Laszlo
              • Sep 2015
              • 28
              Forgive my ignorance here, but since the unit has vertical lines (i.e. lines being generated along the X axis), why would you consider that the Ysus board is the problem?
              Ken
              • R_J
                • 9557
                The noise that is being generated is high frequency and is effecting the scan signal so each line of video signal also carries the noise spikes. and is displayed on each line from top to bottom. or
                It could also be caused by the control board and effect the x drive, again without a scope how do you know.
                Have you removed the y & z boards and cleand the ground connections? Inspect them and see if there is any black corrosion at the ground connections. also check for any poor solder connections.
                • Ken Laszlo
                  • Sep 2015
                  • 28
                  Thanks for your reply.
                  I've checked both X and Y boards - All good - No dry joints as I can tell. In fact, the set is in very good shape, despite being 9 years old.
                  I will get the control board changed - It's very cheap.
                  If that doesn't effect a fix, I can look into other things.
                  Ken
                  • Ken Laszlo
                    • Sep 2015
                    • 28
                    I reflowed the entire Y-Sus board, even though there were no obvious signs of dry joints.
                    In operation, the set does have a slight 'buzz' sound that seems to be coming from a KF13N60 MOSFET on this board. Is this normal?
                    The MOSFET does appear to have seen some 'action' (slight brown discolouration).
                    Thank you
                    Ken
                    • Taterbug
                      • Dec 2013
                      • 114
                      I just picked up a set with the exact same problem. Did you ever find what the culprit was?
                      • satyajit sarkar
                        • Sep 2020
                        • 4
                        • india
                        replace tcon pcb
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Originally posted by satyajit sarkar
                          replace tcon pcb
                          It's not an LCD.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Taterbug
                            • Dec 2013
                            • 114
                            Replaced the t-con board and that fixed the problem. Thanks
                            • ZAINABALDHAIF
                              • Oct 2021
                              • 3
                              • Bahrain
                              Hello..I have a problem with the Smart TV..The type of Supra TV..Do you have any software for Supra TV..55 inches
                              • ZAINABALDHAIF
                                • Oct 2021
                                • 3
                                • Bahrain
                                Originally posted by zainabaldhaif
                                hello..i have a problem with the smart tv..the type of supra tv..do you have any software for supra tv..55 inches
                                • Falki
                                  Colorful LCD Vertical Lines on Samsung ue55es8090
                                  by Falki
                                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                                  A similar issue has been posted as well but also with no actual response ...
                                  08-12-2025, 04:19 AM
                                • afex
                                  Samsung Plasma TV with vertical lines (model PN50B430P2D)
                                  by afex
                                  This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                                  This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                                  I have attached an image of the TV with these bars displaying....
                                  11-08-2021, 09:23 PM
                                • thetonywarren
                                  Samsung PN51E450 Plasma Vertical Lines
                                  by thetonywarren
                                  Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
                                  Any help would be appreciated.....Please let me know.......
                                  02-14-2022, 01:23 PM
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • x_orange90_x
                                  Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                  by x_orange90_x
                                  I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                  The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                  09-04-2023, 12:09 PM
