Samsung PN51E450 Plasma Vertical Lines
  • thetonywarren
    • Feb 2013
    • 149
    Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
    Any help would be appreciated.....Please let me know....
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung PN51E450 Plasma Vertical Lines
    That is a panel problem. It's only going to get worse. Not repairable.
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • afex
      Samsung Plasma TV with vertical lines (model PN50B430P2D)
      by afex
      This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
      This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
      I have attached an image of the TV with these bars displaying....
      11-08-2021, 09:23 PM
    • Stanley1843
      by Stanley1843
      06-29-2024, 11:54 AM
    • x_orange90_x
      Samsung UN46C8000XFXZA vertical bars/horizontal lines
      by x_orange90_x
      I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
      The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
      09-04-2023, 12:09 PM
    • polaro
      Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
      by polaro
      Greetings,
      I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
      08-27-2022, 08:46 AM
