Sanyo DP55360 shuts off
  • TWW
    • Sep 2016
    • 4
    Hello, I'm looking for some help with a TV
    Sanyo DP55360
    It turns off every time after a few seconds of powering on, started like this…
    If the volume was over level 10 & there's sudden loud audio, like an unexpected car crash in a movie, the TV turned off.
    It was repeatable with DVD & Blu-ray, but avoidable at lower volume settings or muted.
    Playing video games, it happened during certain cinematics and busy graphics, high enemy counts for example, regardless of volume level
    It happened through HDMI, composite & component, but not coaxial standard def
    Bad Main?
  • Shock2cure
    Test Subject
    • Jul 2018
    • 140
    Re: Sanyo DP55360 shuts off
    audio amp drawing to much current???
    "Our technologies have surpassed our humanity" ~Einstein
    • TWW
      • Sep 2016
      • 4
      Would that be the IC001 in the lower left of this scan?
      Is there a way to test the amp or a direction you could point me in to find out how?
      ...or should i just look for a new/used board
      • R_J
        • 9627
        Have you checked the voltages from the power supply? are they within spec and do they drop when the fault occurs?
        • TWW
          • Sep 2016
          • 4
          At this point it turns off within 3 seconds of powering on. So I can't test the voltage.
          After a visual inspection of the boards, this cap is the only one that looks a little bloated. Hard to get a good photo, thoughts?
          • karthur
            Vizio D65x-G4 Volume changes on its own
            by karthur
            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
            06-05-2025, 08:13 AM
          • Michale32086
            FUNAI/SANYO FW55D25F Shuts Down Randomly
            by Michale32086
            I have Sanyo 55" TV that randomly shuts off..
            Sometimes it will stay on for 5mins or so, sometimes it shuts off after a min or two...
            When it DOES stay on, it works fine...
            All things being equal, would it be more likely a POWER Board issue or a MAIN Board issue???
            Thanx in advance......
            07-12-2022, 12:41 PM
          • freethink
            Kenwood KR-A70 Receiver Balance changes with volume controls?
            by freethink
            I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
            Yesterday, 07:53 PM
          • crackedprint
            Sony HCD-HX80R Amplifier Volume Control Problem
            by crackedprint
            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
            I have tried a Cold Reset as per the service manual.
            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
            I have looked all the way through the service manual and tried many online...
            01-21-2025, 12:18 PM
          • BigOof
            Marantz SR5007 popping on volume change and mute in Direct Mode
            by BigOof
            I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
            12-12-2024, 06:15 AM
