RCA RTU4853 - wonky video
  • MadeJust
    • Apr 2016
    • 32
    Re: RCA RTU4853 - wonky video
    Oh crap, does the W have to be in the model number as well??
    Zooming in, all the components look the same except for the Samsung chip, which mine shows VTU61B1, and the one I ordered shows VTU61B2.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      It may still work. Be positive.
      • MadeJust
        • Apr 2016
        • 32
        I emailed them and asked if it was the correct part. They asked me for the number directly below the barcode. They got back to me saying it wasnt compatible, but then gave me a link to the correct part.
        So it's ordered and I should have it by the end of the next week (hopefully).
        Fingers crossed!
        • g966321
          Did you get this TV working? I'm curious to know, I have the same model with a broken screen, I took the screen off and the back lights still come on, It would make a nice big light.
          • MadeJust
            • Apr 2016
            • 32
            First replacement I got from them had the same problem but to a lesser extent. This one would start by cycling through solid colors, then the glitchy and stuttering picture with distorted colors and images. After a few cycles of distortion it would work.
            I asked if it was possible I just got a dud. They said it was possible and sent me another one. This one distorts slightly for 15-20 seconds only in the lower 1/3 of the screen, then works ok. There is a slight difference with the last letter on the model number being a different letter for both of them, but I dunno if that's the reason.
            Makes me wonder what's up with these t-con boards. But my TV is working well for the most part so I'm just going to live with it as is.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4544
              • Italy - Milan
              #26
              Can you make a brief new video of the actual defect? Just to confirm a suspect..
              If you have not done it before try to show also how it goes if you detach one at a time the left one and right one flat cable from tcon to panel.
              • MadeJust
                • Apr 2016
                • 32
                There is a video in the first post. Do you want a video of the current board?
                I have tried disconnecting the flat cables, IIRC the picture went snowy. I can try it again this week.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4544
                  • Italy - Milan
                  #28
                  You said the current defect is better than the original so i need a new video, where also you detach the flat cab. I dont know what is IIRC, i'm Italian.
                  • MadeJust
                    • Apr 2016
                    • 32
                    "If I recall correctly"
                    I'll see if I can make a video tonight.
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • Aimbit
                      JBL Flip Essentials - Bluetooth not connecting after a fall - video of board
                      by Aimbit
                      video: https://www.youtube.com/watch?v=S-xBu7m6SwE
                      Hi all. I was given this JBL Flip Essential speaker that 'fell from about 8 feet' and then the bluetooth would no longer function. It seems to power on normally and responds to button presses, but it will not showup on bluetooth for any device I try to connect to it.
                      The bluetooth daughter board has a 26mhz oscillator that I could not get to read the proper frequency so I tried replacing that to no avail. Thought maybe something was wrong with the bluetooth IC it's connected to, so I tried replacing that as well. None...
                      10-28-2024, 09:29 PM
