Some interesting replacement LED strips
+ More Options
Posts
  • mc900fthanna
    Visio M70-C3 LED replacement strips
    by mc900fthanna
    So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
    Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
    11-28-2022, 03:03 PM
  • lmcancu
    RCA RLDED 4331B: 43 inch LED TV: Backlight issue
    by lmcancu
    Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
    Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
    Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
    Instead of putting it back together I decided to replace...
    04-01-2023, 01:11 PM
  • anupkg1985
    Insignia NS-50DF710NA21 Replacement LED strips
    by anupkg1985
    I have this Insignia tv with most of the led's damaged. I'm not able to find the replacement LED strips for the same. The numbers marked on LED strips are -
    LB-GM3030-GJBETTY504XBBB19. Please find the photo for the same. Can somebody help finding replacement/equivalent led strips for the same....
    05-02-2022, 04:59 PM
  • Kingfreddie
    LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
    by Kingfreddie
    Ok.. this is the story:
    Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
    This is kinda how it looked, just that mine were at the bottom of the screen:
    09-11-2021, 01:57 AM
