I found this TV last week and when I plugged it in, it momentarily came on, I was able to see the OSD, and then smoke began pouring out of the back. To most people, that would seem bad, but to me that means an easy job troubleshooting. It turned out to be the inverter transformer, and as you can see from the pictures, it's toasted. I looked on eBay and found the power supplies to be about $100. That's way more than I'm willing to spend. I also noticed that tvdoctorsalesandservice, a reputable seller that I've bought several boards from over the years, had a defective board listed for $55. ShopJimmy also had a repair kit listed, but that would do me no good. I decided to buy the defective board, I ended up getting it for $40 shipped. I didn't know what was wrong with it, but I knew it wasn't the transformer. I expected the failed components to be the ones Shopjimmy has in their repair kit, and I figured I'd just test and swap those components from my board. It turns out to be completely different failed components, but still only took a few minutes to figure it out. The first three pics are my original board. Next two are the replacement board. The IC, the resistor, the diode between them, and the diode with the red band seem to be the only shorted components and those are all OK on my board so I think I have a good chance of this being successful. I'll thoroughly test all surrounding components before powering it on. My biggest concern is what caused the transformer to burn up in the first place. It appears to be the primary side which failed. My thoughts are that it was a bad solder joint. Would I be correct in my belief that if there were ceramic caps behind the panel on this model, and they were bad, the secondary would be the side which burned? Panel sticker number is LC420WUE-SAA1.
Magnavox 42PFL3603D Burnt up inverter transformer.
Tags: None
Re: Magnavox 42PFL3603D Burnt up inverter transformer.
It looks like typical through hole rivet poor solder joints, I have a feeling the primary winding is still OK. I always remove old solder and out in new solder on those through hole rivets.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Fixed! I tested the primary and it seemed ok so I cleaned it up and wrapped six strands of copper wire from some 10ga THHN around the pin and then flooded it with solder. It's not pretty, but it works. I'll still fix the other board, and honestly, I think I have a third one in a box of boards I haven't had time to troubleshoot. Thanks!------------signature starts here------------
https://www.badcaps.net/forum/attach...1&d=1531371244
I have seen this kind of failure many many many many times before.Never stop learning
I was right, I did have another one. It's been in that box since at least May of 2017, but yet I knew I had it. I think I have a photographic memory, but only when it comes to parts.Attached Filesif you find these attachements useful please consider making a small donation to the site
I have never seen one burn all the way through the board like this.https://www.badcaps.net/forum/attach...1&d=1531371244
I have seen this kind of failure many many many many times before.------------signature starts here------------
The one I just dug out of the box has the same exact failed components as the one I got from eBay. It's my son's first birthday so I probably won't have time today, and I'm going out of town Friday until Sunday, so I'll probably get to these on Monday.------------signature starts here------------
I like your new Avatar Good job at the repair too.Comment
Here's some nice pics of the die from the FSQ510 IC. The drain pin was blown off both of them. I can't find any shorted components around it. The MOSFET is incorporated into the IC and i think it failed internally.Attached Filesif you find these attachements useful please consider making a small donation to the site
Second board, the one I got from TV doctor, is fixed. I couldn't find anything else wrong aside from IC U101 (FSQ510), so I decided to take the IC from the working board and put it in one of the others. Before doing that, I compared resistance measurements between the drain and every other pin location with the IC removed. Both boards had very similar measurements. I intend to replace the IC in the working board anyway, so I wasn't worried about potentially frying it. But, it didn't fry. It worked. Surprisingly, Digikey has these in stock. Ordering now.------------signature starts here------------
First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheetHi all,
I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if... -
by learnmoreHello Community,
I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
Peace
LM...11-04-2025, 09:35 AM -
by eccerr0rMy cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
by ohrenHello!
I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
Measured voltages with no load:
After rectifier diodes
12V: 6.17 V
5V: 5.67 V
Secondary transformer pins AC measurement (really don't know if this says anything)
12V: 2-2.5 V
5V: 1.04 V
I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,... -
by mikey5791Hi all,
Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
My questions are
1. How do i test to see if the transformer is in good working condition?
2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
Hope you guys understand what i was asking. My intention is... - Loading...
