Re: Please Help! My Magnavox 50ME314V/F7 Beeping From Power Board
Remove C3214 and then measure the resistance between the two empty pads to see if the resistance will go up much higher than 24 Ohms.
I am not sure if that means the issue is only C3214 or if that was just 1 of a chain of bad components.
question, but should I be using the Ohm setting, the Diode setting, or a different setting to test connectivity?? And I assume the test for connectivity is done while the Main board is NOT receiving power, correct?
