42u2p y & x problem
  • Mrnixdorf
    • Sep 2016
    • 136
    • Morocco
    42u2p y & x problem
    Hi guys,
    I'm seeking your help, i have a samsung plasma 42" with clicking sound when power on. power off after 5 sec, no picture no sound.
    I checked the board, and found that 3 "RJP30E2" and 1 "SF10A400H" where shortned on the 42u2p_Y-Main Board.
    On 42u2p_XM there was no issue.
    I managed to change those component, plugged in, clicks sound again, and now i have 2 "RJH30E2" burned on the XM board . lol
    42u2p Y board
    42u2p X Board
    Is there a workarround on how to fix those boards; cuz something keep burning them.
    I just ordered RJH30E2 because i don't have them in stock.
    Thank you
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: 42u2p y & x problem
    Did you replace all the securing screws back in tightly before you powered up?
    When you replaced the components did you check there was no short circuit between VS and chassis and VA and chassis?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Originally posted by dick_barton
      did you replace all the securing screws back in tightly before you powered up?
      When you replaced the components did you check there was no short circuit between vs and chassis and va and chassis?
      +10
      • Mrnixdorf
        • Sep 2016
        • 136
        • Morocco
        Sorry for the late reply, i was busy a little and thank you for your reply.
        Unfortunatly no, i didn't check before.
        But now on the Y Main unplugged, i don't have short on VA Gnd and VS Gns.
        There's short on VS Gnd on X main because i still have the burned RJH30E2 on this board.
        I'm waiting to get the RJH30E2, what must i check exactly when changing them?
        What's "securing screws back in tightly"??? where are they?
        Thank you
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Thank you
          As shown in the photo.
          • Mrnixdorf
            • Sep 2016
            • 136
            • Morocco
            humm, no i didn't touch them at all.
            Must i change them or remove them???
            They are well placed, and they are connected to GND. what's the matter there?
            • Mrnixdorf
              • Sep 2016
              • 136
              • Morocco
              i would appreciate any help please
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Thank you
                You need to check all of the mosfets, diodes on that board because if you miss a faulty one it will damage the components you replace.
                Also check the resistors connected to the mosfets.
                • Mrnixdorf
                  • Sep 2016
                  • 136
                  • Morocco
                  Thank you Dick_Barton for your reply, i did some check, you can see pictures below.
                  please tell me what to check exactly!!
                  Thank you
                  • Mrnixdorf
                    • Sep 2016
                    • 136
                    • Morocco
                    Anyone please?
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      How did you do your testing of the Z-SUS Bd without removing the screws??
                      • Mrnixdorf
                        • Sep 2016
                        • 136
                        • Morocco
                        What do you mean without removing the screws?????? the board was disasembled from tv case "if this is what you asking", there was a short on RJH30E2, desolder and test them they are faulty.
                        • Mrnixdorf
                          • Sep 2016
                          • 136
                          • Morocco
                          Finally i got the parts today lol that took too much time to come
                          Anyway, after changinf the parts RJH30E2 they got burned immeditaly after trying to turn the tv on.
                          I have change then again, and start connecting cable one by one and trying to turn on the tv to see what happen.
                          In results, im connecting all the boards and cable expect the 42u2p_xb board, the tv turn on normally with black screen, when i connect the 42u2p_xb board the same component burn again.
                          Please help me out
                          • Mrnixdorf
                            • Sep 2016
                            • 136
                            • Morocco
                            I connected the board without the ribbon cable connected, no issue, seems a problem with light panel, is there a way to disassembly the screen fron the light panel to check out?
                            • Mrnixdorf
                              • Sep 2016
                              • 136
                              • Morocco
                              Update : all connected now, no issue with component, tv turn on but still black screen, on 42u2p X Board i have 2 pins with 208v instead of 5v
                              • Mrnixdorf
                                • Sep 2016
                                • 136
                                • Morocco
                                No one???
                                • David L. Chan
                                  • Sep 2020
                                  • Belize
                                  Thank you
                                  Good Day I am new to this forum, I am also really in need to find out the transistor and diode numbers of this board to replace them. mine are all tarnished and cant figure out the numbers. If it is possible I would surely appreciate any help. I am interested in the numbers of the semiconductors that are on the heat sink. for example the RJP..... and the rest of these components.
                                  Thank You
                                  David
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • hugocarmo
                                    Panasonic TX-24A1UN CRT Sound and Input problem.
                                    by hugocarmo
                                    Hi.
                                    I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                    It is imaculate inside, almost no dust or debris inside.
                                    The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                    So I started to look for a service manual, I found one, and started from the beginning.
                                    Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                    04-26-2025, 07:45 PM
                                  • PNI E.
                                    Dyson v15 problem with the dust detector board
                                    by PNI E.
                                    Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
                                    10-02-2025, 10:18 AM
                                  • huj3r
                                    Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                                    by huj3r
                                    Hi there!
                                    I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                                    Photo of the situation after the black shadow dissipates:
                                    After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                                    I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                                    > This indicates HFR Communication error. [ HFR Communication...
                                    08-15-2023, 10:55 AM
