SAMSUNG UE55D6507 - vertical bars / lines
  • olegeisler
    • Dec 2016
    • 100
    • Denmark
    Another freebie I got SAMSUNG UE55D6507 chassis U69A, but this one also looks like it will have to go the scrapyard, unless some of you clever people can give me a hint with some magic
    (I dont have the remote control for this one)
    Symptom : Vertical lines/bars at bootup, see attached picture
    All voltages from power supply OK
    Backlight OK
    My guess : Bad mainboard....
    I will be happy to be corrected
    Service manual + chassis pictures + screen picture attached
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: SAMSUNG UE55D6507 - vertical bars / lines
    Clean and re-seat all cables and connectors at both ends of each to and from the T-CON Bd. Yes it could be a Main Bd. issue or it could be a T-CON Bd issue, also. Not ruling out the Panel, as a last option mind you. Do you have an Oscilloscope??
    • olegeisler
      • Dec 2016
      • 100
      • Denmark
      Yes, I have an oscilloscope, I have all kind of instruments, and knowledge how to use them. So any directions saying I should check something - I am fully able.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Do as I suggested in Post #2. Then we could test the LVDS to see if we have signals from the Main Bd.
        • Diah
          • Feb 2013
          • 6586
          its panel fault 100% water damage
            Did you inspect the connectors?
            This may or may not be applied to your model but it is worth inspecting.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Yes
              • pasdebip
                • Jun 2018
                • 33
                • france
                Hello
                I had the same problem on a samsung UE48C6700.
                I solved it by pressing one of the motherboard chipset with an inner tube wedged between the chipset and the TV cover.
                Try on all the bga on the motherboard, mine works very well for 2 years now .
                In my house it worked.
                • x_orange90_x
                  Samsung UN46C8000XFXZA vertical bars/horizontal lines
                  by x_orange90_x
                  I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                  The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                  09-04-2023, 12:09 PM
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • pni
                  LG 49uf695v vertical coloured lines
                  by pni
                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                  11-14-2025, 03:15 AM
                • polaro
                  Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                  by polaro
                  Greetings,
                  I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                  08-27-2022, 08:46 AM
