Replacement LED's for OD416D11-ZC14F-02 LED strip?
  • check12
    • Nov 2012
    • 103
    Hi all ... below are photo's of the 4 x 11 LED strips.
    The TV is a no name 41.6" Aldi branded Altius A-400F.
    Fault is one strip is out so one or more failed LED's
    Can't find a direct replacement or any info for the OD416D11-ZC14F-02 strips.
    Panel is a CHI MEI INNOLUX V420HJ2-PE6
    This is my first TV LED repair (usually work on pro-audio sound equipment) ... can any of you help me find suitable replacement strips or single LED's?
    Any help well appreciated!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Replacement LED's for OD416D11-ZC14F-02 LED strip?
    You'll need to pop off one of the lenses to be able to see the LED and then measure the dimensions. The positive and negative also need to be noted. You can replace individual LEDs if you can't find a replacement strip.
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      replacement exist, see here.
      Cheers, Janos
      • check12
        • Nov 2012
        • 103
        Already did it ... in the pic below the LED width is 3.5mm and the height is 2.8mm.
        I know what you mean about the polarity for the SMD pads ... do you need me to take one off to see which is the large pad?
        It is only a single LED that is open ... but it failed on the final day of the 3 year warranty so I think it best to replace them all.
        Replacing them all may be a lot faster than waiting for delivery from china ... just had some parts take 40 days to get here.
        Do you need any more info to help identify the LED's?
        Originally posted by yohnsee
        Aha ... thanks for that ... I've been searching all day and found nothing but it turns out I'd been searching with the wrong serial number.
        Ok that gives me a lead but it will probably be much faster for me to replace all the LED's individually than to wait for delivery from china ... I'll see if I can find any closer to the UK.
        If anybody knows anywhere closer that has them please let me know ...
        • check12
          • Nov 2012
          • 103
          What a nightmare this is turning out to be .....
          Ordered replacements from China as detailed above ... advert stated the correct serial numbers (as above) but they have sent the completely wrong parts: 4 x strips of 11 (HL-3F750A28-1101S-03 A2 E334789) the lenses look the same but the strips they have sent are for a 32" TV and the one I have here is 42" ....
          I've popped one of the lenses and the LED's although same size and very similar to look at appear to have a slightly diffrerent colour temp when testing them with my MM.
          I have sent YOYCART.com where I bought them a mail but I'm not holding my breath for a solution.
          Anybody dealt with wrong parts sent from China before?
          • check12
            • Nov 2012
            • 103
            The LED's I need are 3v 3528 or 2835 but seem to have two light emitting elements like the attached image (this pic is a lot clearer than my photo above).
            They are a cold (high) colour temperature when lit dimly with my DMM's diode test function.
            I've just wasted £30 trying to get replacements from China ... can anybody help me find replacements of the correct type from a reliable seller?
            • diif
              • Feb 2014
              • 6978
              • England
              I have a small number of these in my stash, looks very similar to yours.
              • check12
                • Nov 2012
                • 103
                Hi diif, thanks for the reply ... yes those look very similar.
                Here's a turn up for the books though ... the chinese supplier has got in touch with me through the yoycart agent and is adament that although the set they sent are for a 32" TV they are a direct replacement for the correct original serial number and that is what they usually send out as a replacment for the 42" strips I was looking for.
                I replied that they do not line up with the holes on the back white reflector sheet that goes over the LED strips ... and he has said that instead of putting them behind the sheet with the holes in that I should stick them to it on the front of it instead.
                I have no experience with this ... what do you think?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  The LED strips get warm/hot so sticking them to the plastic backing is a silly idea IMO.
                  If you are going down that route then stick them to the metal backing as they were originally and cut new holes in the white sheet.
                  • check12
                    • Nov 2012
                    • 103
                    When laid side by and centre to centre there isn't a huge amount of difference between the two different strips ... the centres of the outside LED's on each end of the shorter strips are 22mm in from the ones on the originals when the centres are aligned... do you think using these would light the screen properly?
                    Looks worse with the two ends starting together ... but centre to centre the spread looks a lot better. Here's a pic to give you an idea of the difference. (original correct strip in front)
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      The Chinese replacements will work but as previously advised you would have to ct holes in the reflector paper for the lens to pass through. I have stuck strips on the paper before on other TVs and they are still working, but the better thing to do is cut new holes. Wherever there may be a gap the Diffuser sheet will spread the light out evenly so don't worry about that.
                      • check12
                        • Nov 2012
                        • 103
                        Hi Andrew .. so you think the shorter strips will be fine in a 42" TV ?
                        ... this is my first TV repair and I'd have been far happier with the correct parts. Mind you I'm not even sure if you can actually get new original parts for it now and I'm pretty sure it would be difficult to return or get a refund for what they have sent ....
                        Up to now I have been using the diode test function on my DMM to test the individual diodes on the faulty set but I've just realised that I don't think it's testing reliably. I have a couple of 30v variable power supplies what would be the best way to use these to test the diodes. Would 30v be enough to test strips of 11 diodes and what should I set the current limiting at?
                        • jetadm123
                          • 2169
                          I feel your pain of getting something different from what you ordered. If you can't resolve the issue with the seller, then maybe remove the LED's from the new strip and replace the bad one's on the existing strip? Time consuming, but it's a possible alternative.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            You can do it like this too. Stagger the strips placement. That is, put the 1st one fully left then the 2nd fully right and so on. The Diffuser sheet w3ill take care of the spread. It works don't worry
                            • check12
                              • Nov 2012
                              • 103
                              Hi jet .. thanks ... the seller is adament that these are fine for the 42" ... so I think that's about it really as far as he and the shipping agent are concerned. Initially it was the top row that went out .. so I only tested the top row with the diode test function on my DMM and found one LED that wouldn't light so took it for granted that was the culprit... but now I have tested them all (and some of the new one's) it seems quite a few do not light with the low voltage from the DMM ... so I upped it a little using a bench PS and current limiting resistor and it seems now that the top row is actually fine and the fault lies on one of the other rows.
                              So not sure exactly at the moment how many diodes are genuinely good or not on the original set.
                              Can anyone tell me the optimum voltage/current limit for testing as I'm not sure where the threshold lies for diodes that are maybe on their way out ?
                              Aha! ... that's another option for me to think about ... if I get time later or tomorrow I'll take out the old strips and try the new one's in place ... both aligned and staggered ... I'll take a couple of pics and you guys can tell me what you think is best ...
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                I have never bought strips that a new from China and found them not working. I use the all the time and these days a lot of LED TVs are coming in with bad backlights problem. I use the strips with the 10 LEDs and fit them in on up to 50" screens. Wirte them appropriately and they work and are still working as far as I know since 2015.
                                I would recommend that you change out all the old strips even if they test good. They will fail shortly thereafter and you will have to go in again. Replace all and close the Panel up once and for all.
                                • check12
                                  • Nov 2012
                                  • 103
                                  Wow strips of 10 up to 50" ... is that where the staggering comes in? or are they the 6v LED's?
                                  Yeah don't worry now I know I can use them I'll be swapping in the full set of new one's ... just want to learn as much as possible from the old one's rather than just swapping them over without thinking about it.
                                  I'm just amazed that it's so difficult to identify LED's and find any accurate spec. for them ... why do the LED's never have any serial numbers?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    Max. Forward Current: 350MA
                                    Max. Forward Voltage: 3.0-3.6V
                                    on the 3v leds i brought recently
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      max. Forward current: 350ma
                                      max. Forward voltage: 3.0-3.6v
                                      +10
                                      • check12
                                        • Nov 2012
                                        • 103
                                        Yeah that looks familiar ... is that about typical average then for 3v LED's? or are some a lot different?
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • smort
                                          Backlight Polkadarks
                                          by smort
                                          Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
                                          I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
                                          03-11-2025, 12:33 AM
                                        • mc900fthanna
                                          Visio M70-C3 LED replacement strips
                                          by mc900fthanna
                                          So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
                                          Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
                                          11-28-2022, 03:03 PM
                                        • Firentiosi
                                          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                          by Firentiosi
                                          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                          The issues are as follows: the...
                                          11-27-2024, 12:33 AM
