MOSFET Eqivalent of IGBT RJP63K2 in SAMSUNG PLASMA TVC SMPS
  • Ahakim
    • Apr 2013
    • 64
    Any MOSFET equivalent of RJP63K2 ...found blown in a SAMSUNG plasma TV SMPS?? IF there is ..Please help.. many thanks..
  • Tanko2
    • Dec 2017
    • 5
    • Nigeria
    Re: MOSFET Eqivalent of IGBT RJP63K2 in SAMSUNG PLASMA TVC SMPS
    Am very also interested in samsung plasma IGBT RJH30E2 equivalent pls any help
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Funny I have a Sammy right now and those same IGBT's out of circuit for testing.
      They call me......."threadkiller"
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Part Number : RJH30E2
        Manufactures : Renesas
        Function : 360V 30A IGBT
        You can use any of the last 5 in the plasma panel list at the bottom.
        • Tanko2
          • Dec 2017
          • 5
          • Nigeria
          Thanks sir
          • Tanko2
            • Dec 2017
            • 5
            • Nigeria
            Was able to get the last one on that list which is GT30J124
            Type of IGBT Channel: N-Channel
            Maximum Power Dissipation (Pc), W: 26
            Maximum Collector-Emitter Voltage |Vce|, V: 600
            Collector-Emitter saturation Voltage |Vcesat|, V:2.4
            . hope is not too much for it sir
            Maximum Collector Current |Ic|, A: 200(pulse)
            • mikkele86
              Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
              by mikkele86
              hello.
              I have two power amplifiers, both having their IGBT blown on the PSU.
              The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
              I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
              I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
              So I though i missed a capacitor or diode. I removed...
              01-06-2024, 06:45 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • tofik
              Igbt rjp63k2 smd vs tht
              by tofik
              Hello guys,
              I have a shorted IGBT transistor RJP63K2 TO220F (THT).
              Could I replace it with a RJP63K2 TO-263 (which is SMD)?
              Apart from less convenience of soldering this element, should it be working fine?
              I could not find a datasheet for RJP63K2 TO-263 but noticed that for different transistors, the Power Dissipation value is different for different types of the body (TO220F and TO-263 for example).
              07-19-2023, 05:43 AM
            • Nooy
              VGA MOSfet permanently shorted and loss of MOSfet pad
              by Nooy
              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
              02-14-2024, 02:26 AM
            • redbaron1007
              Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
              by redbaron1007
              I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
              Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
              09-09-2025, 11:10 AM
