Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
    • 12331
    • U.S.
    Re: Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
    Originally posted by kevinm34232
    Did not try yet, will try shortly. It's questionable if it will accept the USB drive without being able to power up.
    update:
    TV will not take firmware file automatically...
      Service manual on post #2, if you look at PDF page 30 LVDS connector, there is pin called 'PANEL ERROR' pin.
      Your panel is Samsung so SLCD looks to be the one for your TV, you can verify the pin out.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        So what do we have on a recap:
        1. TV switching on and staying on
        2. Backlight turn on and stay on
        3. All signals from the Main Bd. and voltages on PSU are present, except
        4. T-CON ON signal from Main Bd.
        If you connect the 3.3V to the T-CON ON wire on the PSU you would have to make sure and disconnect it from the Main Bd. You would have to cut to wire midway of the connectors to leave enough space to join it back up.
        Just leave it connected long enough to see if there is an image on the Screen/Panel.
        If you get an image, then the Main Bd. is faulty.
        • kevinm34232
          • May 2012
          • 1884
          TV does not turn on and stay on. Instantly 5 blink code.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            OK. I am now thinking your Main Bd. is bad and you should look for a replacement board. I think.
              Did you look at the 'PANEL ERROR' pin?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                #27
                Your Main Bd. Nos. would be
                1-895-172-11
                (1P-011BJ00-4011)
                  • 12331
                  • U.S.
                  #28
                  Faulty eeprom?
                    • 12331
                    • U.S.
                    #29
                    Looks like you need to find out why there's no tcon on signal coming from mainboard, did you check everything on tcon with your meter?
                      • 12331
                      • U.S.
                      #30
                      A schematic of the mainboard would help.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        #31
                        Did you follow up on this to see if there is any voltage at that pin?? Of course this would be with everything connected.
                          Sorry about the schematic for the main board, this is the one I am referring to:
                          • kevinm34232
                            • May 2012
                            • 1884
                            I will check the that pin when I get home and follow up thank you..
                              • 12331
                              • U.S.
                              #34
                              Page 13 in budm's service manual looks good, maybe you can trace the tcon on wire back to mainboard then follow the traces to where they go, did you check those two IC voltage regulators right by the connector and any fuses you might have?
                                • 12331
                                • U.S.
                                #35
                                http://assets.shopjimmy.com/media/ca...M/IMG_1134.JPG pic. of mainboard.
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  I had no luck when I searched for a main board the other day, it's gonna be one of those hard to find ones..
                                  But first let's determine if it's that board for sure.
                                    • 12331
                                    • U.S.
                                    #37
                                    If I recall, the 40, 46 and 55 ex640 will all work.
                                      • 12331
                                      • U.S.
                                      #38
                                      Ebay Hong Kong 110 U.S plus 10 shipping, might need to translate page, your right sold out about everywhere, saw one for 192 bucks but that's sick.
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Ya not spending that much on an older 46", not worth it.. thanks for looking though..
                                        Budm as for the PANEL ERR#:
                                        On initial plug in to AC and/or each time power button is pressed, pin goes to 0.872V, then drops quickly back to 0V.
                                        The same thing happens if I disconnect CN4002 (the other LVDS connector), or either one or both of the ribbons going to the panel.
                                        With the T-Con completely disconnected from main board, PANEL ERR# goes to 3.3V immediately.
                                        Not sure what to make of that voltage reading whether it should be low or high..
                                        I tried grounding out the 3.3V PANEL ERR# pin with the T-Con disconnected, same 5 blinks.
                                          Well at least you did try to trick the ERROR pin signal but still get the same 5-error code. I am not sure at this point if you have T-CON or main board problem.
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
