Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
Re: Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
Service manual on post #2, if you look at PDF page 30 LVDS connector, there is pin called 'PANEL ERROR' pin.
Your panel is Samsung so SLCD looks to be the one for your TV, you can verify the pin out.Last edited by budm; 05-16-2018, 10:32 PM.Never stop learning
So what do we have on a recap:
1. TV switching on and staying on
2. Backlight turn on and stay on
3. All signals from the Main Bd. and voltages on PSU are present, except
4. T-CON ON signal from Main Bd.
If you connect the 3.3V to the T-CON ON wire on the PSU you would have to make sure and disconnect it from the Main Bd. You would have to cut to wire midway of the connectors to leave enough space to join it back up.
Just leave it connected long enough to see if there is an image on the Screen/Panel.
If you get an image, then the Main Bd. is faulty.Comment
TV does not turn on and stay on. Instantly 5 blink code.Comment
OK. I am now thinking your Main Bd. is bad and you should look for a replacement board. I think.Comment
Your Main Bd. Nos. would be
1-895-172-11
(1P-011BJ00-4011)Comment
Looks like you need to find out why there's no tcon on signal coming from mainboard, did you check everything on tcon with your meter?Comment
A schematic of the mainboard would help.Comment
Sorry about the schematic for the main board, this is the one I am referring to:Never stop learning
Page 13 in budm's service manual looks good, maybe you can trace the tcon on wire back to mainboard then follow the traces to where they go, did you check those two IC voltage regulators right by the connector and any fuses you might have?Last edited by nomoresonys; 05-17-2018, 04:11 PM.Comment
http://assets.shopjimmy.com/media/ca...M/IMG_1134.JPG pic. of mainboard.Comment
I had no luck when I searched for a main board the other day, it's gonna be one of those hard to find ones..
But first let's determine if it's that board for sure.Comment
If I recall, the 40, 46 and 55 ex640 will all work.Comment
Ebay Hong Kong 110 U.S plus 10 shipping, might need to translate page, your right sold out about everywhere, saw one for 192 bucks but that's sick.Comment
Ya not spending that much on an older 46", not worth it.. thanks for looking though..
Budm as for the PANEL ERR#:
On initial plug in to AC and/or each time power button is pressed, pin goes to 0.872V, then drops quickly back to 0V.
The same thing happens if I disconnect CN4002 (the other LVDS connector), or either one or both of the ribbons going to the panel.
With the T-Con completely disconnected from main board, PANEL ERR# goes to 3.3V immediately.
Not sure what to make of that voltage reading whether it should be low or high..
I tried grounding out the 3.3V PANEL ERR# pin with the T-Con disconnected, same 5 blinks.Last edited by kevinm34232; 05-17-2018, 07:17 PM.Comment
Well at least you did try to trick the ERROR pin signal but still get the same 5-error code. I am not sure at this point if you have T-CON or main board problem.Never stop learning
by brithepi2kHi,
I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
cheers...5 Photos -
by iglitareHi,
i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
Backlight seems to work, Sound (Setup menu after reset) works.
If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
With my small knowledge i would think at least the cables are good.
Can this happen because of a bad tcon board?
Or is it always a bad/shorted... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by thelankanguyThe TV shows a black screen with no image.
TCON ribbon connectors were disconnected individually for image and there was no half image even.
Later both ribbons were disconnected and TCON voltages were tested.
12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
There is also a short to ground in this circled inductor.
Is this a TCON issue or something else ?... -
by GoodCapDudeHi everyone. First post on Badcaps!
I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot.... - Loading...
