Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
  • kevinm34232
    • May 2012
    • 1884
    Hopefully someone is familiar with this model/series. I couldn't find a SM or much online, except that 5 blinks seems to be T-Con error. I checked T-Con fuse and surrounding diodes and they are good. I disconnected the LVDS cables, same. Next I disconnected ribbons to the panel, same.
    I disconnected main board, and forced POWER ON, and BL-ON, and backlights come up and all voltages normal. When I force T-Con ON I get 12V on the T-Con-VCC-12V. So power supply seems fine.
    With main board hooked up, I'll get a short voltage at POWER ON when hitting the power button. But never any voltage at T-Con ON.
    Also, I get 3.3V at BL-ERR, is that supposed to be high when working? Backlights do come on steady when forced on..
    So I'm not sure if there is actually some problem on the T-Con, or there is a main board issue...
    Any ideas? Thanks!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-46EX640 won't turn on, 5 blinks on standby light.
    There would be two flat cables coming off the Main Bd. to the T-CON Bd. Unplug them, carefully, from the T-CON Bd. and try a turn ON. If voltages come up and are steady then the Main Bd. might be OK. I have attached the SM for you. I repaired two of these recently. One was a PSU issue and the other was a double image, I fixed on the T-CON Bd.
    • kevinm34232
      • May 2012
      • 1884
      I tried unplugging the cables to the T-Con board with no change, but I assumed it's looking for a signal from the T-Con and if it doesn't get it, it won't send T-Con ON?
      I downloaded the firmware file I was gonna try that when I get back to it..
      Do we know what it's checking on T-Con board to give the T-Con ON signal?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        The T-CON ON signal comes from The Main Bd. and tells the PSU to supply 12V to the T-CON Bd. I wanted to verify the Main Bd. was OK. 5 blinks is T-CON Bd problem. So then if the Main Bd. produces the T-CON ON signal and the PSU produces the 12V to supply the T-CON but when it reaches the T-CON Bd. a problem on the T-CON shuts down the PSU. OR the Main Bd. is not sending the T-CON ON signal to the PSU and so the T-CON never gets powered and so the system says T-CON Bd. problem. BTW I was getting 7 blinks which pointed to a Main Bd. problem but when I tested the PSU it was bad and so got anew PSU and the TV came on and work perfectly. So sometimes the blink codes do mislead us.
          What is the LCD panel model number? I can see the white sticker on the panel but the picture is not clear enough to read the numbers.
          BTW, what happen if you disconnect those two cables between the LCD panel and the T-CON board?
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Also what is the T-CON Bd Part No. on the white sticker at the bottom of the board?
            • kevinm34232
              • May 2012
              • 1884
              I will have to get the part #s when I get back home.
              As far as the T-Con ON signal, the main board is not sending it. I can hit the power button while Im getting the 5 blinks code, and Power ON will go to 3.3V for a second, but nothing on the T-Con ON.
              However if I apply 3.3V to T-Con ON, I do get the T-Con 12V so power supply is good.
              • kevinm34232
                • May 2012
                • 1884
                I'm 99% sure I tried that first and there was no change but I will confirm again.
                  So if you leave the T-CON force on in place, you still get 5 blink codes?
                    Originally posted by kevinm34232
                    I tried that first and there is no change.
                    I am talking about the two flat cables between the T-CON and the panel, not the two flat cables between T-CON and the main board.
                    • kevinm34232
                      • May 2012
                      • 1884
                      Correct I did disconnect those ribbons,I just need to make sure that when I did that, I had the LVDS cables reconnected which I'm pretty sure I did but I will recheck.
                      • kevinm34232
                        • May 2012
                        • 1884
                        I only tried this with the main board disconnected to make sure the power board was good. I had backlights and all voltages.
                        • kevinm34232
                          • May 2012
                          • 1884
                          Panel # LTY460HJ07 A02/ LJ96-05959A
                          T-Con: Sony LJ94-24765D
                            • 12323
                            • U.S.
                            So did you try the firmware apply?
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              Same Panel and T-CON Nos. I repaired. The T-CON is about 40.00 USD. I bought a T-CON Bd. off e-bay as I thought the Level Shifter IC was causing the double image. I eventually cut-off the CKPV1,2&3 and STVP signals with some stationery tape to cure the double image issue. So I have a good T-CON Bd. now.
                                • 12323
                                • U.S.
                                http://www.ustvparts.com/apps/websto...s/show/3939160 Appears to be a match but triple check if you get it.
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  T
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    I'd like to figure out what T-Con ON error is looking for. There doesn't appear to be any short so not sure what the 5 blinks is all about.
                                    My guess is main board giving false error, but that's why I'm asking the experts..
                                    Do you guys think it's a good idea to send 3.3V to T-Con ON, while connected to main board to see if TV will turn on?
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      Did not try yet, will try shortly. It's questionable if it will accept the USB drive without being able to power up.
                                      update:
                                      TV will not take firmware file automatically...
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Just to confirm, same 5 blinks with 2 ribbon cables from T-Con to panel disconnected.
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
