panasonic THL32P6D BACK LIGHT PROBLEM
  • pawan007
    • May 2018
    • 7
    • india
    SIR PLZ HELP ME panasonic THL32P6D BACK LIGHT PROBLEM
    SET STAND BY VOLTGE OK BUT INVATOR BORD EXTERA VOLT 3.3 VOLT
    SET BACK LIGHT ON BUT LOGIC MOTHER BOARD MISSING BL VOLT
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: panasonic THL32P6D BACK LIGHT PROBLEM
    Is that the correct model number?
      +1
      We also require good clear pictures of the whole backside of the TV showing all the board, and then the picture of the whole board of each board.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8273
        sounds like the main board isn't sending BLon.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          +1 That's the only conclusion you can reach with the limited information supplied. Mainboard fault.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8273
            I have had little success in fixing a BLon issue on the main board. Most of the time the main IC wasn't sending it, requiring an IC replacement. Usually it's just better to replace the main board all together.
              If the only problem is the BL-ON control signal but if ALL other functions of the main board are OK, then you can use T-CON power on to turn on the backlights circuit.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8273
                or this way as budm described. That works too.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Hmmm....I never thought of that. Very good and workable idea.
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                  • boyebaran
                    hisense 65k560 back light problem
                    by boyebaran
                    hi to all
                    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                    please advise me tnx
                    05-20-2025, 07:11 AM
                  • Green Probe
                    Recapping a Denon AVR X6400h SMPS
                    by Green Probe
                    (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                    Disclaimer: I'm an amateur hobbyist and will get things wrong.
                    Always use caution when working around mains power and high voltage capacitors!
                    Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                    SYMPTOMS:
                    -No display...
                    07-18-2025, 03:36 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • usbdevice
                    Acer X223HQ (Version Bbd) on/off-power-cycling
                    by usbdevice
                    Hi all
                    There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                    https://www.badcaps.net/forum/showthread.php?t=50657
                    https://www.badcaps.net/forum/showthread.php?t=40512
                    The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                    It's my dad's old monitor. He...
                    08-05-2022, 02:21 AM
