Vizio VF550M 55" LCD - PS cap values please anyone?
  • nonsub
    • May 2018
    • 84
    Hi folks.
    Does anyone know what caps are used in the power supply for these? Per search indication there is no known schematic for these.
    Since this is my only TV I am hoping to do my repairs in one shot without missing any of my favorite shows so I would like to have parts on hand rather than pull unit, check then wait for parts order.
    These are probably common values even suggestions of what to stock up on would be better than nothing.
    Also anyone have insight maybe into something I read on a similar unit that stated "replace all caps except the big one." I take it this would be noted just because it's only really small caps that fail/leak/bulge?
    Thanks!!!
    Re: Vizio VF550M 55" LCD - PS cap values please anyone?
    I use PANASONIC FM/FC/FR for all my repair, just look at the value and the dimension of the caps, since PS can be more than one revision so you have to get to the board to see exactly what you have.
    There is more than one revision of the TV also:
    http://www.shopjimmy.com/catalogsear...q=Vizio+VF550M
    • nonsub
      • May 2018
      • 84
      Thanks. Thing is where I am I will have to order/have shipped so there would be a gap between removing and servicing where I would be in TV withdrawal. That's why I'd like get the caps first. Even if I have to buy extras values based on uncertainty that would be fine. So if anyone knows these that would be great.
      thx!
        That will be tough because you do not know which power supply is being used in that TV.
        Typical values are:
        Cold side
        1000uF 10V
        1200uF 10V
        2200uF 10V
        470uF 10V
        680uF 10V
        470uF 25V
        680uF 25V
        1000uF 25V
        1200uF 25V
        470uF 35V
        680uF 35V
        1000uF 35V
        1200uF 35V
        Hot side:
        22uF 50V
        33uF 50v
        47uF 50v
        56uF 50V
        • ecking767
          • Oct 2009
          • 492
          I will change out the large cap (the big one), only because of the age of your TV.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • proxneo
            Recapping Sony ICF-SW55 - verifying cap values
            by proxneo
            Dear reader
            I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
            At the moment, I have selected replacements based on the following list of values:
            3 x 470uF 10VDC
            3 x 4.7uF 35VDC
            4 x 47uF 50VDC
            8 x 22uF 6.3 VDC
            1 x 220uF 6.3VDC
            5 x 100uF 6.3VDC
            Which...
            06-21-2023, 12:38 AM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • rashidjafar
            Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
            by rashidjafar
            I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
            Values for :-
            PC43 : Capacitor [3x1.5mm]
            PL7 : Inductor [2x1mm]
            PC39 : Capacitor [1x0.5mm]
            Any ideas would be appreciated.
            I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
            08-07-2025, 05:10 PM
