Re: Samsung UN60H6203AF LED TV Screen Won't Turn On
Hi, sorry to bother, but any ideas?
I tried to get the lighting right on the pocs without reflection. I didnt have the tconn board uncovered.Leave a comment:
You can only use Voltage mode when testing live circuit, do not use Ohm or Diode mode to test live circuit, you can damage your meter and the board.
What you did is providing the - (Cathode) return to circuit ground through your meter, instead of going through the MOSFET and current sensing resistor to circuit ground.
Show us good clear straight shot pictures of the whole top and bottom side of YOUR power supply board, and also the whole back side of the TV showing all the boards.Leave a comment:
I just put the multimeter into diode test mode and measured from chassis gnd to that very last - and all leds light up bright to full strngth. Same for the very last +. ???Leave a comment:
By the way, i am jamie from NOLA, sorry for jumping straight in guys.Leave a comment:
Hi, old thread so hope someone can still help. Same bn44-00775a board on a un60h6203. Original problem was one strip of lights went out so i got the strobing. Replaced the entire set of backlight strings and no lights at all. Forced backlight on mode and still 405v with no lights. I tested the individual leds again and all of them work. I have continuity on the wiring harness and measure 405v at the + of the top string and have voltage at each + on each strip all the way down enough that it should light the strips. Like the thread above, I can measure V from chassis grnd to s+ or s- at the connector pin on the psb and the lights all barely light up. I can also measure V from chassis gnd to the very last - on the very bottom led strip and all leds light very dimly. If unplugged for a whiile, i can plug psb in and all leds shine bright for a few milliseconds, then completely off. Seems like a continuity problem but i can figure out where or what else to try. Any ideas?Leave a comment:
OP: how comfortable are you with opening this TV up?
In lieu of doing that, i would suggest getting an LED backlight tester. See: http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
You can find the same thing on eBay for cheaper - it's probably the best $30-$50 that you can spend on trouble shooting backlight issues.
Anyway, once you get it, apply the red probe to the + lead of the backlight wire, and the black probe to the - nead of the backlight wire. Make sure you have it DISCONNECTED from your power board first. Report back when you have had a chance to do so.
If the backlights turn on and stay on, then we can say it's potentially a power board problem. If the backlights DON"T turn on at all, or they shut off during testing, then it's an LED strip problem.Leave a comment:
You can buy a replacement power supply board and find out, you can also buy LED tester for about $35.
Also see my post 11, 26.Last edited by budm; 05-19-2018, 02:24 PM.Leave a comment:
The batteries in the multimeter are brand new. How should I proceed?Last edited by vergezee; 05-12-2018, 09:57 AM.Leave a comment:
And that is why when the Black lead was on GND and the Red lead on S- the backlights came on.Last edited by Andrew F. Ali; 05-10-2018, 06:49 AM.Leave a comment:
The meter may have low batteries Voltage but the reported Voltage readings indicate the needed Voltage and control Voltages are present.
The Voltage reading in post #10 indicated open circuit in the second string of the LED.Leave a comment:
I think there is something wrong with your meter. Check the battery on it.Leave a comment:
Does anyone know what the proper voltage readings should be?Leave a comment:
Does this look correct?
Pin1 A13V = 18V
Pin3 A13V = 18V
Pin5 A13V = 19V
Pin7 A13V = 18V
Pin9 GND
Pin 2 UD = 4V
Pin 4 PWM_BLU = 4V
Pin 6 PS_ON = 4V
Pin 8 GND
Pin 10 GNDLeave a comment:
by JunkmanJimboSamsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
Please help. Thanks in advance! -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ? -
by String2016I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
by andrestecnoHi everyone,
I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
Thanks in advance!
- Loading...
