Samsung LN40D550K1FXZA Backlight Problem
    Re: Samsung LN40D550K1FXZA Backlight Problem
    Originally posted by classicmac
    I removed CI818 and tested it and was getting ~.47-.5. It should be a .47uf capacitor right? I'm attaching a picture for reference.
    That cap is Polypropylene type.
      • 12081
      • U.S.
      This one LD-4088 is also one of the ones on shopjimmy list. https://www.ebay.com/itm/APEX-LD-408...MAAOSw4GVZ4OPf
        • 12081
        • U.S.
        Not sure, maybe the info. shopjimmy has there in post #18 is wrong?
          • 12081
          • U.S.
          Your inverter board probably looks like this. https://www.ebay.com/itm/Samsung-40-...UAAOSwMgdXxdUd
            • 12081
            • U.S.
            Would it be easier for him to verify the PFC circuit if the inverter board was not connected to the powersupply?
              • 12081
              • U.S.
              #26
              I'm a little new to this. Is there something specific I should test on the inverter board?
              Inverter board testing, couldn't find your exact model so might not be very useful.
              https://www.youtube.com/watch?v=oE6K4xBVweA
              • classicmac
                • Aug 2013
                • 13
                Thanks everyone for your suggestions. I measured voltage at the capacitors again and it doesn't look like it goes over 360-380v. Is that an acceptable voltage? They only reach that voltage for a split second then the voltage drops down again.
                I'm attaching a picture of the inverter board. Any suggestions on what to check next?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  #28
                  I tried disconnected the main board to test the backlight as suggested in the troubleshooting manual attached to post https://www.badcaps.net/forum/showthread.php?p=792496. I get the same behavior when I connect power where the backlight just flickers on then turns off again. I'm attaching a picture of the power supply board. I don't see any visibly failed components or bulging/leaking capacitors.
                  If you carry out this check again can you measure the voltage across the large capacitor using your meter probes between the two legs of the capacitor and is is steady?
                    Remove the white fuse with purple stripe right next to the main filter cap and then turn the TV on and see if the Voltage on the main cap stays on 380V or so without dropping back down to 160VDC.
                    • classicmac
                      • Aug 2013
                      • 13
                      I removed the fuse and powered the television on and the voltage is still at 160V. It is steady at that voltage. Anything else I should check?
                        OK, I see why will get only 160VDC on the main caps after tracing out the fuse connection, that fuse is for the the STBY power supply and the Inverter Transformer driver circuit, I was trying to isolate the Inverter transformer driver circuits from the rest of the power supply to see if the PFC Voltage will stay up at 380vdc or not.
                        Right now we may have PFC circuit problem, or Inverter circuit is drawing too much current and cause the PFC to shutdown, or the Inverter circuit detect error so it sends the error signal to shutdown the circuit..
                        So have all the boards connected back in place then put red probe of DC V meter on Pin 12 (LD = Lamp Detect)) of connector CNI801, Black probe on Pin 8 (GND) then Turn on the TV to see what you GET. Do the same on pin 9 (OVP = Over Voltage Protection).
                        • classicmac
                          • Aug 2013
                          • 13
                          I am getting 11.83VDC on pin 12 and 0VDC on pin 9.
                            LD is OK, I not sure the pin 9 OVP <1V = bad OR = good
                            • classicmac
                              • Aug 2013
                              • 13
                              I just did another test. When I plug the television in I see pin 9 briefly jump to .4VDC before dropping to 0.
                              • classicmac
                                • Aug 2013
                                • 13
                                Does anyone have any ideas on how to isolate the problem to a component or board? Should I try replacing ICP801 as suggested in the other thread?
                                • classicmac
                                  • Aug 2013
                                  • 13
                                  Thanks so much for the link to your other thread neilc6! I replaced ICP801 and the TV is back to life. Thanks everyone for your help and suggestions.
                                    09-07-2024, 05:50 AM
                                  • C152Heavy
                                    by C152Heavy
                                    Summary for TL-DR readers:
                                    • VCC pin (18) of PFC...
                                    01-11-2023, 02:53 PM
                                  • sansanpartida
                                    Samsung QE82Q70RAT no backlight
                                    by sansanpartida
                                    Hi everyone!
                                    Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                    My issue: No backlight.
                                    Model: QE82Q70RAT
                                    Type No: QE82Q70RAT
                                    The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                    So hopefully, I can fix this cheaper.
                                    05-22-2024, 06:56 AM
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • Warrensmith
                                    Samsung BN44-00807E Low Backlight
                                    by Warrensmith
                                    Symptom is dim backlight - this set came in with almost no backlight.
                                    Samsung UN55JU6500FX2A
                                    1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                                    2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                                    Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                                    10-27-2022, 07:09 AM
