Samsung LN40D550K1FXZA Backlight Problem
  • classicmac
    • Aug 2013
    • 13
    I'm having trouble with a Samsung LN40D550K1FXZA where the backlight does not function properly. When I turn the television on the backlight flickers on momentarily and I can see the Samsung logo for half a second. The backlight then turns off.
    The main board does seem to fully boot. I can hear sound when the television is on. I can also see picture doing the flashlight test.
    I tried disconnected the main board to test the backlight as suggested in the troubleshooting manual attached to post https://www.badcaps.net/forum/showthread.php?p=792496. I get the same behavior when I connect power where the backlight just flickers on then turns off again. I'm attaching a picture of the power supply board. I don't see any visibly failed components or bulging/leaking capacitors.
    Does anyone have any suggestions on where I should go from here? I would appreciate any help or advice.
    Thanks!
    Michael
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung LN40D550K1FXZA Backlight Problem
    So the backlights do not come on as per the fast-track guide, so possible inverter fault or / lamp fault.
    Can you measure the voltages at CI801
    Can you post pictures of all the circuit boards at the back of the set and how they connect to each other?
    • neilc6
      • Nov 2015
      • 1550
      Check this thread
      https://www.badcaps.net/forum/showthread.php?t=58093
        • 12307
        • U.S.
        If your power supply voltages are all good, probably a bad ccf/lamp or bad transformer on inverter board or something else wrong with inverter board, you could grab an inverter board and try it, usually pretty reasonable prices on them BUT won't fix issue if it's a bad ccfl/lamp, there's some good videos on testing inverter boards on youtube, also check any fuses that might be on inverter board, fuses will start with F on label next to them.
          Beside checking the PFC Voltage, check capacitance of CI818 also.
          • classicmac
            • Aug 2013
            • 13
            Originally posted by neilc6
            Thanks for the link to the other thread neilc6. Are the capacitors I highlighted in the attached photo the "main filter caps?" I'm getting 163V across them. The other thread seems to say that I should be seeing 380-400V.
            Neilc6 I see you had a similar problem and replacing ICP801 fixed it. Is there anything I can do to verify ICP801 has failed before I order a replacement? Thank you everyone for your responses and suggestions.
            • neilc6
              • Nov 2015
              • 1550
              Yes those are the main filter caps. Voltage is measured with black on the negative lead and not chassis ground. In my case, the PFC voltage spiked up when first plugged in going into an overvoltage situation. If your backlights do come on momentarily, it would indicate the PFC voltage comes on. You will need to monitor it when the TV is both turned on and plugged in. Be careful, it's high voltage and alligator clips would work best.
              I would also check the usual suspects CP820, CI818 and DP810 assuming the designators are the same for your power supply board.
                So the 160V reading on the cap is measure when the TV is turned on? May be you leave the probes connected to the cap then turn the TV on to see if the meter shows the Voltage jumps up to 400V range or not, you will have to put meter scale at higher than 200V scale.
                There is also PFC Diode DP810 that needs to be tested to find out if it has leakage or shorted out.
                  • 12307
                  • U.S.
                  Yep, need to verify the PFC circuit, check those in post 7, CI818 is a problem in many power supplies.
                  • classicmac
                    • Aug 2013
                    • 13
                    I did more testing and the voltage across the capacitors does jump to ~400 for a split second before dropping down to ~160. Is there anything else I should verify?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      You need to check or replace the capacitor as mentioned by the others above since it tends to be one of the faults recognised for this power supply.
                      • classicmac
                        • Aug 2013
                        • 13
                        I removed CI818 and tested it and was getting ~.47-.5. It should be a .47uf capacitor right? I'm attaching a picture for reference.
                          • 12307
                          • U.S.
                          I'd test the inverter board.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Yes, 2W474K value is 0.47uf 450VDC Polyester Film type.
                            • arenat
                              • Nov 2015
                              • 22
                              • Argentina
                              Most Samung power supply of that era have an OVP , if go over 415V disable it.
                              Measure that voltage again .
                              • classicmac
                                • Aug 2013
                                • 13
                                I'm a little new to this. Is there something specific I should test on the inverter board?
                                  • 12307
                                  • U.S.
                                  This one has a number that appears to match but the board looks different. $7.50 https://www.ebay.com/itm/Coby-Sony-L...YAAOSw-ldZZ5mG
                                    • 12307
                                    • U.S.
                                    According to shopjimmy the KDL-40X400 is one of the boards that will work, if the seller has his info. correct.
                                    http://www.shopjimmy.com/auo-19-40t0...t-inverter.htm Shopjimmy must have made an error here, because these boards look way different than the one in post #24.
                                      • 12307
                                      • U.S.
                                      Can you upload a pic. of your inverter board?
                                        You have power supply/Inverter transformer driver board, the primary inverter transformers winding are driven by the your power supply/ Inverter driver board. I would check the resistance of the primary winding, but more concern right now is the PFC Voltage of over 400VDC.
                                        Your Inverter transformer board should look something like this:
                                        http://www.shopjimmy.com/samsung-lj9...t-inverter.htm
                                        or
                                        Or: http://www.shopjimmy.com/cmo-27-d056...t-inverter.htm
                                        Show us the pictures of your inverter transformer board.
                                          09-07-2024, 05:50 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
