haier 58" le58f3281 screen goes black after 1/2 hour or so
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    The screen goes blank after 1/2 hour sound remains looks like led backlight issue.Is this common problem with this unit anyone know.Just wanted get an idea how to proceed.Seems the leds dont short out as same amount of time each time.Looks like overload overheat issue.
    Re: haier 58" le58f3281 screen goes black after 1/2 hour or so
    They drive the LED's way too hard and with poor thermal management.
    Look to see if you can turn down the Backlights level (not Brightness) on all input mode as low as possible to see if the backlights will stay on longer or not.
    • sputnikoff
      • Feb 2016
      • 203
      • canada
      Thanks bud .I will give it a try.I did remove the power supply and saw some questionable solder connections on power supply transformers.I resoldered those so along with backlight dimming it may have worked.The set has been on foe 4 hours now gonna leave it overnight see what happens.Will update soon.
      • sputnikoff
        • Feb 2016
        • 203
        • canada
        Update bud I turned down leds backlight adjustment about 2 days ago to 60% roughly and unit continues to run after inputting 8893 after menu ....great call on that one....thanks again.
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          Bud had some success.I done more investigation and found led board had become un soldered as in pic so i corrected this and lamps returned to normal.However now have bigger issue where only 1/2 screen comes on.If i remove ribbon cable from left side on t-con i get 1/2 picture.I was very careful with disassembly amd everything looks fine.i seated the cables numerous times but now screen blacks out with 2 cables on t-con.
            • 12330
            • U.S.
            Recheck your soldering job carefully, strange that this symptom showed up right after.
            • sputnikoff
              • Feb 2016
              • 203
              • canada
              I only soldered the led rails ,now its either tcon or shorted screen very strange.
                • 12330
                • U.S.
                Factory reset.
                • sputnikoff
                  • Feb 2016
                  • 203
                  • canada
                  Can't factory reset without screen.Any way confirm left side shorted?I tried switch cables locations to no avail.possible tcon went bad ?
                    • 12330
                    • U.S.
                    Get the service manual.
                    • sputnikoff
                      • Feb 2016
                      • 203
                      • canada
                      I have checked electrotanya and manualslib.Any other sources out there?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Check that the gold contacts at the end of the ribbon cable have not lifted. This can happen. You may need to use a magnifying glass.
                        You were flipping the top bar of the connector up to release and push back down to secure?
                        • sputnikoff
                          • Feb 2016
                          • 203
                          • canada
                          So it could be just replace ribbon cable.I will check that for sure.
                          • VcemPzd
                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                            by VcemPzd
                            Hello everyone !
                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                            04-28-2025, 10:14 AM
                          • DaniK
                            Acer Aspire E5-574-52RH - black screen
                            by DaniK
                            I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                            Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                            Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                            Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                            The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                            Symptoms are:
                            - random black screen after displaying Acer logo...
                            02-21-2024, 06:27 AM
                          • turmix
                            AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                            by turmix
                            Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                            The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                            At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                            During another reassembly, I made a mistake, and...
                            01-29-2024, 03:48 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • Online_internet
                            Lenovo G50 NM-361 - power on, charging LED on, black screen, no CAPS LOCK and NUM LOCK LEDs
                            by Online_internet
                            I'm having a problem with a lenovo diagnosis and I'm asking for help. This is an older laptop, I am leaving out the viability of repair. I am anxious to know and understand the problem.
                            Model: lenovo G50
                            Motherboard model: ACLU3/ACLU4 NM-361 Rev: 1.0
                            - Laptop turns on
                            - CPU and GPU start up (slowly warming up)
                            - HDD starts
                            - fan is running
                            - power and charging LED lights up
                            - CAPS LOCK AND NUM LOCK LEDs are not present
                            - no image, including on external monitor
                            - I have 20v, 5v, 3.3v, 3v, 1.35v
                            - BIOS battery...
                            02-14-2024, 07:06 AM
