Lenovo G50 NM-361 - power on, charging LED on, black screen, no CAPS LOCK and NUM LOCK LEDs
This topic has been answered.
  • Online_internet
    • 15
    • Poland
    I'm having a problem with a lenovo diagnosis and I'm asking for help. This is an older laptop, I am leaving out the viability of repair. I am anxious to know and understand the problem.
    Model: lenovo G50
    Motherboard model: ACLU3/ACLU4 NM-361 Rev: 1.0
    - Laptop turns on
    - CPU and GPU start up (slowly warming up)
    - HDD starts
    - fan is running
    - power and charging LED lights up
    - CAPS LOCK AND NUM LOCK LEDs are not present
    - no image, including on external monitor
    - I have 20v, 5v, 3.3v, 3v, 1.35v
    - BIOS battery checked has 3v
    - BIOS reset via jumper and battery removal did nothing
    - RAM swaps did not give anything
    - no short between pin 4 (GND) and 8 (+) of BIOS chip
    - fuses are not shorted
    - no visual damage
    - no water damage
    - started with a spontaneous black image
    What do you think? BIOS problem, something related to the keyboard or maybe EC (which gets 3v) or maybe ADAPTER_ID? Do you have any ideas on how to eliminate the various suspicions?​
  • Answer selected by Online_internet at 02-25-2024, 04:30 AM.
    mcplslg123
    • Jun 2015
    • 7262
    • india
    Yes,stop troubleshooting for now unless you flash bios. Once we're sure its not a bios issue ,we can always proceed further.
    • mon2
      • 14789
      My 2-bits (half a nibble),
      a) check if the clock on the EC is oscillating
      b) check the voltage to ground on each inductor. Each inductor is a buck regulator that will take the high side voltage of ~19v and lower it to a suitable one for that power rail if all is well. Any missing voltages? Any voltage that is not considered to be in the normal range?
      c) yes, check the bios for corruption. Not sure of adapter_id details on Lenovo but is this requirement on Dell and HP models.
      d) is the power adapter the original and recommended one for this logic board?
      • Online_internet
        • 15
        • Poland
        Thank you for your response and for trying to help me resolve my issue.
        a) I do not yet own an oscilloscope, only a multimeter. Is there any other way without using an oscilloscope?
        b) The measurement of the voltage drop across the coils is:
        PL9 0,117V
        PL302 0,560V
        PL303 0,363V
        PL304 0,388V
        PL307 0,323V
        PL701 0,168V
        PL704 0,033V​ - Should I suspect this coil?
        c) On the 8th (VCC) pin of the BIOS I have 3v
        d) Yes, the power supply is factory supplied with the laptop.
        I didn't notice any of the components getting too hot.
        • Online_internet
          • 15
          • Poland
          Or does this measurement rather indicate GPU resistance?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Since the mb is turning on with voltage present on coils,oscillator is likely fine AD_ID is also not likely the issue here. I suggest to take these steps:
            01.Flash known good clean me bios and remember to take backup of existing bios.
            02.Check DRAMRST# present on ram slot 30 or not?
            Btw, do you have a dc supply? IF yes, then what is the consumption after pressing the power button
            01.With ram stick
            02.Without ram stick
            • Sephir0th
              • Oct 2020
              • 1289
              It would be really important to know whether the CPU is powered at all. Missing +VCC_CORE is not a usual symptom of BIOS corruption. And the thermal observation points to that the CPU is not fully powered.
              FairRepair on YouTube
              • Online_internet
                • 15
                • Poland
                Thank you for your interest in the topic and support.
                I have taken measurements as suggested. I didn't mention before that the laptop starts by itself after connecting the power adapter, without pressing the power button first. When I hold the power button for a few seconds it looks like it shuts down, I can turn it on later with the button.
                When I connect the power supply it jumps to 0.56A, in about 3sec. it drops to 0.02A, and then oscillates around these values:
                - with one RAM (4GB) it jumps between 0.47-0.6A
                - with two RAM (4+4GB) 0.47-0.66A
                - without RAM 0.39A
                The board starts by itself when I hold down the power button, it seems to shut down and then it draws 0.02A
                Voltage measurement on the plugged-in power supply:
                PL9 1.8v (CPU_CORE)
                PL302 1.95v (BATT+)(LX_CHG)
                PL303 3.35v (+3VALW)(+3VALW_P)(+3VLX)
                PL304 5.1v (+5VALW)(+5VALW_P)(+5VLX)
                PL307 1.37v (+1.35V)(LX_1.35V)
                PL701 1v (+1.05VS)(1_05VS_LX)
                PL704 1v (+VGA_CORE)(VGA_PHASE1)
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Almost all major rails are up and running.
                  Check DRAMRST# present or not on pin30 of ram slot.
                  Try flasing known good clean me bios.
                  • Online_internet
                    • 15
                    • Poland
                    I checked the voltage on the 30th pin (CCPU_DRAMRST#), it is:
                    - with RAM in the slot 1.35v
                    - without RAM in the slot 0.125v​
                    I ordered a programmer, it should arrive this week, then I will try to do a BIOS flash.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      • Online_internet
                        • 15
                        • Poland
                        I did a BIOS flash and the laptop came back to life. Thank you to everyone involved in helping me.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Glad to know you fixed it.
                          • coasterghost
                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                            by coasterghost
                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                            System Hardware:
                            Processor: AMD Ryzen 7 PRO 5850U
                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                            09-08-2025, 10:46 PM
                          • thesame
                            Lenovo TB-X605F fake charging after charging connector replacement.
                            by thesame
                            Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
                            04-03-2024, 03:14 AM
                          • nikolayu
                            Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
                            by nikolayu
                            I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
                            When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
                            Other usbc is charging fine,
                            I installed lates bios and firmwares for thunderbolt and battery.
                            Could be faulty JHL8040R controller?
                            08-31-2024, 11:08 AM
                          • B2L_Repairs
                            Lenovo g50-80 charging led flashing but laptop not switching on
                            by B2L_Repairs
                            I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this...
                            01-19-2025, 12:28 PM
                          • Cepriuko
                            Lenovo S40-40 All-in-One bios pass lock
                            by Cepriuko
                            I have two devices that have a BIOS password. Can anyone help unlock them?
                            Product Family: Lenovo S40-40
                            S/N: P9018TKN and P9018XHH
                            Board: 6050A2626201 A01
                            Also, it gives an error when starting (photo)...
                            09-22-2025, 01:40 AM
