Sharp LC-60LE600U no op - waveforms
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sharp LC-60LE600U no op - waveforms
    I would read up on the threads on this site about lifting the panel away and how people have done such a large panel. Suspect it's a two person operation.
    Do not mix up the direction and position of the filters screens behind the panel or you will be in trouble.
    Have a look at this page
    • legg
      • Apr 2018
      • 25
      • canada
      I rigged up a more rugged substitute with the right profile, then showed the result to my neighbor, for whom I'm doing the work as a favor. He didn't seem distressed by the darkish corner of the resulting display. He knows how much the replacement lamp will be and knows the amount of work involved.
      Wrap it up, he says. He'll live with it.
      I suspect a lot of owners would have said the same, if, in the original design, one lamp section failure didn't cause the whole unit to die.
      Imagine other equipment doing the same thing.
      One windsheild wiper craps out and your car locks up.......
      oh, wait.......that's exactly what happens with some models, isn't it.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I'm a little puzzled here. I thought the backlights were failing to come on because you found a faulty led string but now you say
        • mmartell
          • Oct 2013
          • 3189
          The first sentence is what you're looking for. He's running a dummy load in place of the offending string to keep the supply happy.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            So the dummy load did work.
            • legg
              • Apr 2018
              • 25
              • canada
              #26
              A firm 'itive'.
              Considering the flammability of the materials in one of these displays, I might sympathize with the protective function used in the thing, however I'm guessing it was just easier/cheaper to do. Given the reluctance of the bad string to arc on a flare, or draw anything when probed to double normal voltages in testing, there seems little likelihood of it doing so in the future, unstressed and cold.
              I've attached a schematic of the final plate assembly used. Drawing from the junk pile, it used metal clad mil spec parts bolted to the plate - which was mounted on the empty metal panel above the main board, on unused stand-offs pre-existing there. No big rise in air resulted, probably due to the unchanged power consumption in that area.
              • roy.zhero
                Sharp LC50LE752E no picture and backlight, indicator light is lit
                by roy.zhero
                I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
                When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
                When I hold the force-on-combination it will turn on. It then shows a perfect...
                09-20-2020, 01:57 PM
              • canadaboy25
                Sharp LC-60LE920UN LED TV won't turn on. Blinking indicator
                by canadaboy25
                Hey everyone, I have a Sharp LC-60LE920UN LED TV that I just picked up. Plugging the TV in only gives a flashing power indicator. According to the service manual, one fast flash and one slow flash means a lamp failure. I assumed it would just be a failed LED so I started testing all of the led circuits. Each circuit lit up when power was applied.
                I did some searching and apparently there is a way to force the TV on for older models by plugging the TV in with some buttons held. However, this TV does not have physical buttons but instead has capacitive touch buttons. I have tried...
                03-18-2021, 03:34 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • sefoster
                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                by sefoster
                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                11-20-2022, 09:29 AM
              • gavenb
                Sharp LC-80LE661U 80 inch
                by gavenb
                Hi folks!
                I have a LC-80LE661U that had some interesting issues.
                Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                11-12-2023, 02:05 PM
