Emerson LF501EM4A...first succesful screen replacement!!
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    I picked up this Emerson LF510EM4A last night with a broken screen. I got the same model TV from a Laundromat about a month ago. It had bad LED's and a good display screen.
    When I checked the panel part numbers they were the same!
    This morning I started swapping the screen. I tried lifting the broken one by hand. It flexed and cracked right down the middle. That's when I said it's time to go to Harbor Freight and get a couple suction cups.
    After getting them I took apart the Laundromat TV, suction cupped the screen and it came out and went back in perfect!
    The moral of the story: suction cups are a must for screen removal and replacement! They're just as handy as a bag around bread, a can around Pepsi and a pocket on a t-shirt!
    They call me......."threadkiller"
  • nomoresonys
    • 12201
    • U.S.
    Re: Emerson LF501EM4A...first succesful screen replacement!!
    Nice job, I think suction cups are the best way to equalize the pressure, it seems like they are just too fragile to grab up from laying flat with 2 or 3 people even, if I had to try it without suction cups, I would try it from an upright position instead of laying flat and that would be a tough job too.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      What suction cups did you get? pictures? Thinking of getting some,I got a few 60" and a 55" curved that I have been stalling on in fear of crcking the screen.
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        Here you go!
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          Macbook Air M2 A2681 Kernel panics after screen replacement
          by reformatt
          Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
          It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
