CCTV Vertical Coloured Lines Rolling Across Screen Interference
  • TornadoAlley101
    ʙᴀᴅᴄᴀᴘꜱ ᴀᴅᴍɪɴ
    • Mar 2020
    • 24
    Re: CCTV Vertical Coloured Lines Rolling Across Screen Interference
    Originally posted by R_J
    So as soon as a second channel is connected (any camera of the 16) the lines appear. If just touching the second cameras bnc to the dvr does'nt give the lines, then its nothing to do with the ground. It is likey just that the dvr has poor isolation and filtering between the video channels. when you have 2 signals that are basically the same they will will produce harmonics that will show up in the image, just like having 2 audio signals thet beat together will produce harmonics
    So are you saying my DVR is bad quality and it is causing the lines? I was thinking of upgrading it to begin with but I guess now I have a reason for it now. Now that you say that, the cameras do glitch whenever I tap the Bnc connector on the back of the DVR.
    • R_J
      • Jun 2012
      • 9627
      I'm not saying it is cheap, it is just that when you combine two or more of the same video signal they need to be kept seperate, If one video signal starts to combine with the other, there will be an issue. If you have a way of trying another unit that would be the best, that way you can confirm the problem.
      • TornadoAlley101
        ʙᴀᴅᴄᴀᴘꜱ ᴀᴅᴍɪɴ
        • Mar 2020
        • 24
        Do you think it is some type of power interference? Do you think having multiple cables running next to each other is messing up their power and causing interference?
        • R_J
          • Jun 2012
          • 9627
          If it was a power issue, then the 4 cameras on the one splitter would not have the problem, the camera power is DC so it would not cause this type of interference. The problem is with the video and having shielded cable is the way to go so there won't be any interference. Running multiple shielded cables is done all the time without a problem. Don't you have ant extra monitors around that would have video in? Connect a couple cameras straight to seperate monitors and I bet they don't show the interference.
          • TornadoAlley101
            ʙᴀᴅᴄᴀᴘꜱ ᴀᴅᴍɪɴ
            • Mar 2020
            • 24
            Unfortunately I do not have any monitors supporting this type of input. I tried a video/bnc adapter but the video did not work.
            • TornadoAlley
              • Jan 2020
              I am looking to purchase a Dahua DVR but I have no idea from what seller I can purchase it from. I want it to be official and not some DVR with fake firmware or whatever from an unofficial reseller. I want to purchase it from Amazon but there are so many listings from different sellers that I don't even know which is real. For example, there are 3 different companies on Amazon named "DahuaOEM", "DAHUA", and "Dahua Technology". I would like to know which one is authentic or if any of them are even are authentic. I want to make this purchase knowing that I will be getting the right DVR and not some knock off re branded version that doesn't even have the same features and will possibly be vulnerable to being hacked. Thanks!
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                Most of the stuff Lorex has, is rebranded Dahua.
                • TornadoAlley101
                  ʙᴀᴅᴄᴀᴘꜱ ᴀᴅᴍɪɴ
                  • Mar 2020
                  • 24
                  I am mostly interested in a DVR with Dahua software though. I also want the same Alarm IO and Smart features (face detection, missing object, smart search) that the Dahua DVR offers. It is very hard to find this with Lorex systems though. Any other suggestions?
                  Here is a link for the DVR that I am looking to buy: https://www.amazon.com/gp/product/B072DX5417
                  The only issue is that I have no idea if the seller "Q1C1" is authorized.
                  • AleksShamles
                    • Jun 2021
                    • Швеция
                    #49
                    I think that you bought a defective CCTV and the better option for you would be to buy a new one.
                    • BadmanRasta
                      Banned
                      • May 2021
                      • 6
                      • Mexico
                      #50
                      Good day to you! The camera matrix may be damaged if such problems occur. This could have been caused by physical damage. You should contact the master to see what the possible problem is. If you have to replace the camera, then I would advise you to save a little money and buy a complete set of ajax security system. I have been using this for quite some time and so far I have not had any problems with such systems. You may find it interesting to read more on the Internet. Good luck with your camera!
                      • alfatv
                        • Sep 2020
                        • 353
                        To check if it's DVR, connect cameras with short wires next to DVR.
                        • bulkchart32
                          i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
                          by bulkchart32
                          i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
                          06-19-2025, 02:37 AM
                        • SoporteHR
                          PSU For CCTV - noise or interference in the image seen from the camera
                          by SoporteHR
                          Hi all.
                          Receive a warm greeting.
                          I have a centralized power source for CCTV. Model SP200B S88
                          New, zero use.
                          It turns out that the CCTV HD cameras were connected, most of the cameras present noise in the image seen on the monitor.
                          Check, grounding, interference with other electrical cables in relation to the video cable, etc.
                          The source was replaced by another and the cameras worked perfectly.
                          Now checking at the plate level this source, everything looks good, suspecting that it was a problem...
                          12-09-2019, 05:13 AM
                        • Zelek11
                          Panasonic Plasma screen interference on left half of screen
                          by Zelek11
                          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                          10-14-2022, 04:54 PM
                        • eccerr0r
                          Log periodic antenna to Coaxial cable... balun right?
                          by eccerr0r
                          I acquired a (large) used rooftop log periodic broadcast reception antenna and it didn't come with wiring. I figure I could use it for parts if nothing else but first I'd like to see if this thing actually works for receiving distant stations.
                          From passing from amateur knowledge, these log periodic antennas need to be matched to the impedance of coaxial cable, nevermind the balanced nature to the unbalanced nature of co-ax. So I'll need to locate a balun.
                          So I was wondering about people who worked on rooftop terrestrial broadcast antennas...are these log periodic...
                          05-14-2022, 06:42 PM
                        • jason123
                          ASUS PG27V Rolling Image - TCON?
                          by jason123
                          Hi there,
                          My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
                          I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
                          It does this even with the monitor not connected to a computer / graphics card....
                          11-01-2025, 05:41 PM
