Phillips TV no backlight
  • DjKrish
    • Oct 2012
    • 354
    • SG
    I have a 55 inch Phillips TV thats powering up just fine but no voltage on the socket thats connecting to the LEDs. I have used a torchlight to the screen and theres image on the screen. So its clearly the LED voltages missing. When i use a multimeter to measure the voltage, the voltage starts high and then fades to zero voltage. Weird. A sign driver IC failing? I have tried high and low to find the service manual but failed. Anyone happens to have a service manual for this?
    PS : Ive tried another power supply borrowed from a friend and the panel works fine.
    Model Phillips 50PFA4500S
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Phillips TV no backlight
    If the LED backlights have failed, it is normal for the Driver to send 'high' voltage to the connector pin/s at start-up and if it does not detect a load fade to 'zero'. So this is an indication the Driver is good. It seems far-fetched that 'another power supply borrowed from a friend' makes the panel work fine.
    • steviewonder
      • Dec 2013
      • 183
      • england
      +1
      I agree with Andrew.that is a classic sign of a L.E.D failure.,at least with every other set i have repaired...(thousands)...
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Ok, you claim that way. I unplugged the back light cable from the SMPS, the voltage still dropping and fading to zero when plug in power. Why is that? Why when i try another similar power supply, the LED is fine? Ive even opened up the panel to see if any LED failed, all seems working fine.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          The driver is not detecting a load and therefore will go into protect mode as it would do if the led strings are open circuit.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            So you are saying that with the original power supply, the backlights do not come on but when you try another power supply the backlights work.
            Are the two power supplies identical. If not, what is the part number of the power supply.
            Do you have pictures of the original power supply
            What is the part number written on the original power supply.
            • DjKrish
              • Oct 2012
              • 354
              • SG
              YES. Its from the same model TV.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                If your power supply is model 715G6338 then schematic found on page 33 of the attached manual.
                What are the voltages on the 3 pins of DP8101
                • DjKrish
                  • Oct 2012
                  • 354
                  • SG
                  I dont see DP but i see D8101. Is that it?
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Mistyped, yes D8101
                      • 12323
                      • U.S.
                      Did you check the voltages of the 2 filter capacitors, in standby and tv powered on? in the HIGH VOLTAGE/HOT SIDE.
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        I managed to replace the led driver IC, it worked, there was picture light and everything. for 1 minute. Then the IC died and back to no light and no voltage
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          What were the results of:-
                          What are the voltages on the 3 pins of D8101
                          • DjKrish
                            • Oct 2012
                            • 354
                            • SG
                            I was just about to check the voltages, the D8108 diode left and right leg had 35V and middle voltage was dropping. The i switched off the power supply and switched on again, the light is back. I was like what?
                            The led backlight legs (Red Pin) has 70V each on both red cables.
                            Update, after a few switch off and on, now the voltage disappeared. The D8108 has no voltage. 0 Voltage. Looks like something is not right. I have already resoldered all the smd and thru hole components. No cold joints.
                            • DjKrish
                              • Oct 2012
                              • 354
                              • SG
                              After soldering a few smd components. The backlight is stable at every on and off. Led output Voltage is stable at 70.1V. When i put to standby, voltage goes to zero. When i turn on again, backlight comes on, voltage steady at 70.1V
                              If i keep it on standby like 10 or 20 mins and then turn on again, the backlight fails again to turn on as theres no voltage. So this time i tried probing where the voltage stops, i use my digital multimeter on AC mode and stick the black to ground and the red to one of the resistor thats R9103 leg as in the picture, suddenly the backlight comes back. Now isn't thats weird?
                              If i kept it turned on with the backlight, it works for hours without any problem. Sounds like it needs a kickstart.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Check the values of the following components are within specification
                                R9101 1M +/- 1%
                                R9102 1M +/- 5%
                                R9103 1M +/- 5%
                                R9104 22K +/- 1%
                                C9101 10nF
                                C9102 100nF
                                and also the solder connections of IC9101
                                • DjKrish
                                  • Oct 2012
                                  • 354
                                  • SG
                                  R9101 1M +/- 1%
                                  R9102 1M +/- 5%
                                  R9103 1M +/- 5%
                                  R9104 22K +/- 1%
                                  C9101 10nF
                                  C9102 100nF
                                  R9101 1M +/- 1% - 984M
                                  R9102 1M +/- 5% - 984M
                                  R9103 1M +/- 5% - 943M
                                  R9104 22K +/- 1% - 19.9K
                                  C9101 10nF - 8.86NF
                                  C9102 100nF - 105NF going down really slow 1 by 1 digit
                                  IC9109 has been replaced with new IC.
                                  When turn on for the very first time for the day, it works. Standby and turn on again backlight gone. While in ON mode, touch the resistor leg of R9103 with multimeter on AC mode, the backlight comes back
                                    • 12323
                                    • U.S.
                                    So did you test R9103 with your meter?
                                    • DjKrish
                                      • Oct 2012
                                      • 354
                                      • SG
                                      Yes, the reading is as above.
                                        • 12323
                                        • U.S.
                                        Ok, my bad, I read it but it didn't register lol, must be something weak on that circuit maybe? what does it trace out to?
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • gabrielA7
                                          Macbook pro A1706 / Backlight flex cable compatibility
                                          by gabrielA7
                                          Hey guys!!
                                          I’ve got a question here!
                                          I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                                          Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                                          Here’s what the bot told me:
                                          I said to him: “I’m going to install the 821-01229-A.”
                                          ChatGPT replied:
                                          Understood — but before you solder or install the 821-01229-A,
                                          11-11-2025, 03:26 PM
                                        • triplefour
                                          TCL 75S421 has sound but no backlight not even a flash
                                          by triplefour
                                          TCL 75S421
                                          PSU BOARD: 40-L402H8-PWD1CG
                                          it shows not even a flash of backlight when powering up.
                                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                          with mb connected, PSON...
                                          11-17-2023, 09:54 PM
