Vizio M55-C2 HASE BACKLIGHT NO PICTURE
+ More Options
Posts
  • Leo K
    • Apr 2018
    I have a Vizio 55in 4K TV model number m55 - C2 the problem is it has no picture but does have backlight and sound. When powering on the logo flashes for a Split Second I have tested all voltages they're all good but the voltages from the output on the t-con board are not present or are very low at the ribbon cable connector test points I have replaced mainboard bord and t-con bord. Still having same problem please can you help me figure this one out really would like to get this TV up and live again thanksο»Ώ.
  • freccia
    • Mar 2012
    • 26
    • Malta
    Re: Vizio M55-C2 HASE BACKLIGHT NO PICTURE
    have you measured the voltage on the input of the t-con on the test points?
    • gavric
      Vizio M70-C3 Half picture is bad, main board on its last leg?
      by gavric
      Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
      When tv powers on vizio V logo shows nice on whole screen. picture 1
      When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
      When i start youtube picture shows on left side fine, right is all scrambled. pic 2
      When i click video to start playing picture goes black(like when you change...
      09-02-2021, 08:55 PM
    • ggil44
      Vizio M65-E0 No Picture, No Sound
      by ggil44
      Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
      09-03-2024, 08:30 PM
    • maricm
      Vizio m65-c1 picture flashing on and off on the screen
      by maricm
      HI all,
      hope someone point to the possible issue before I start buying replacement parts.
      Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
      Backlight stays on all the time,
      Sound works fine.
      screen keeps changing form black to full picture in about 1sec intervals.
      Picture looks fine with no visible artifacts.
      I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
      Disconnecting left and right ribbons on...
      11-25-2023, 06:32 PM
    • csmith
      Vizio D50u-D1 Powers up no picture
      by csmith
      I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
      Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
      supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
      issue. Set will power up with remote but not power off....
      07-11-2025, 11:52 AM
    • Fly_Among_Stars
      VIZIO E70-E3 Half picture with half TCON
      by Fly_Among_Stars
      I have a VIZIO E70-E3.
      Symptoms: Black screen, no picture, but LED backlights are working.
      I probed the power board and voltages are as listed on the board.
      Main board appears fine, too.
      I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
      There are two separate ribbon cables feeding the LCD.
      If both are connected, the screen is black.
      If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
      04-24-2023, 08:20 PM
