E701i-E3 70" LED Horizontal Line
  • freakaftr8
    • Oct 2012
    • 3743
    Re: E701i-E3 70" LED Horizontal Line
    That is the look you get when both tabs on both sides of the panel had failed. Hopefully fussing with the right side did not short the left side even though you removed the right side hopefully it's not too late. Will see what you get when you get another T con..
    • Michale32086
      • Nov 2011
      • 1453
      The TCON should be in Thu... I'll update the thread once I have news..
      Thanx again for all the help, everyone...
      • Michale32086
        • Nov 2011
        • 1453
        Well, the part came in late yesterday.. Didn't have time to do more than to throw it on and power up the TV..
        All I got was a backlight.. Nothing on the display..
        Is there a way to use a voltmeter to check the TCON to make sure I didn't get a TCON that was already blown??
        • nomoresonys
          • 12323
          • U.S.
          https://www.youtube.com/watch?v=yTnkOfwBGGE
          • Michale32086
            • Nov 2011
            • 1453
            Thanx, NoMore...
            Yea, it looks like this TCON board has a blown component.. No voltages on any of the points..
            Is there a way to test the viability of the component itself off of the TCON board?? As I mentioned, I have several of these boards. If I can confirm a quality component then that might help me fix a TCON...
            • nomoresonys
              • 12323
              • U.S.
              #26
              I think in that video it shows think its a voltage regulator hes testing, says a bad panel takes that one regulator out quite often.
              • freakaftr8
                • Oct 2012
                • 3743
                No need to check this transistor off the tcon board if it is bad it will read that either way on or off the board. Transistor operates the supply voltage to the PWM. Without it, there is no dividing of the voltages for the panel to. Function.
                This is what you need.
                QF which is a RTR020N05 2a 45v n channel SOT-23 style mosfet and it goes here. See pic attached
                • Michale32086
                  • Nov 2011
                  • 1453
                  Yea.. Last time I had this almost exact problem with this exact model, it turned out to be LVDS cables..
                  I might try to replace these, just fer sheets and greens..
                  But i am getting a bad feeling about this...
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Yeah I have a bad feeling too you might have screwed the pooch on fussing with the cables instead of just removing them as it could have shorted the left drivers as well unfortunately. The pics you provided earlier shows what a panel looks like when both driver ribbons have failed on both sides. There is no horizontal driving of the vertical sourcing so the panel doesn't know what to deal with the information that is being addressed vertically
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Yea..
                      I should have a new set of LVDS cables this weekend. Crossing my fingers...
                      Thanx again to all for the assist...
                      • Michale32086
                        • Nov 2011
                        • 1453
                        Final dispo on this...
                        No joy in Muddville today...
                        New TCON, new LVDS cables, still the same old glitchy look...
                        Thanx to all for the help... But my stoopidity wins the day.. :^/
                        • budwich
                          • Jul 2015
                          • 3097
                          you did recheck the bottom corner cables... the one on the "right" which should have been removed because you pulled the edge boards on that side.... and the one other the other side which you may have played with but not reseated properly.
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Yep, I checked it.. Unclipped it, then jiggled it to reseat it, then re-clipped the tab...
                            • Ihandyrepair
                              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                              by Ihandyrepair
                              Hi guys
                              I just started fixing 4k TV few months ago. so I am still learning a lot
                              I got this tv from friend complaint is ghosting or horizontal lines on image.
                              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                              then it started to show the ghosting white image.
                              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                              it has 3 thin small boards at the bottom of the...
                              12-05-2022, 04:18 PM
                            • cubytus
                              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                              by cubytus
                              Hi to all,
                              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                              01-10-2024, 01:26 AM
                            • labello
                              Lg43UJ620V horizontal line
                              by labello
                              Hi guys I have this tv and in one side of the pannel it shows some line i also cleaned the camble notting, although I found an smd capacitor on the pcb (there's no tcon on this model) but I can't find the same model thanks
                              02-20-2025, 02:52 AM
                            • labello
                              by labello
                              02-20-2025, 02:45 AM
                            • rstrube
                              ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                              by rstrube
                              Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                              Hi Everyone,
                              I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                              Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                              11-23-2025, 01:37 PM
