Recalibration needed after Main/A board replacement?
  • NYKing
    • 17
    Hi all, this is just a general question for you folks who had main/A boards replaced and care about image fidelity...I was wondering after the main/A board for a plasma or LCD TV is replaced, do you need to recalibrate the TV again (hiring a pro or using your own colorimeter) or can you simply enter in the same color/white balance values you had before. Since the panel is the same, I would think you can use the same values again but I am not sure. Thanks for your time.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Recalibration needed after Main/A board replacement?
    I would guess that if you re enter everything, it should be back to normal. I never have or had a tv calibrated , just watch 'em.
    • NYKing
      • 17
      Thanks for your input, TVTimmy! I am very obsessive when it comes to squeezing the most image quality out of my TVs and that means performing a proper calibration for each one. It involves quite a bit of time and effort using colorimeters, slides and dedicated software like CalMan so if there is no need to repeat the process, I would be relieved. I know the main/A board has the color management bits but I am not sure If these boards are all uniform in that regard or have enough variation to warrant recalibration.
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
        by JDC
        ONN 100012588
        Issue: No Power, Then Rebooting After Main Board Change
        Short answer: replace main board and power board
        Technical answer: replace main board and Q306 & Q307 on power board.
        Long answer:
        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
        07-15-2022, 07:39 AM
