Recalibration needed after Main/A board replacement?
  • NYKing
    • 17
    Hi all, this is just a general question for you folks who had main/A boards replaced and care about image fidelity...I was wondering after the main/A board for a plasma or LCD TV is replaced, do you need to recalibrate the TV again (hiring a pro or using your own colorimeter) or can you simply enter in the same color/white balance values you had before. Since the panel is the same, I would think you can use the same values again but I am not sure. Thanks for your time.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Recalibration needed after Main/A board replacement?
    I would guess that if you re enter everything, it should be back to normal. I never have or had a tv calibrated , just watch 'em.
    • NYKing
      • 17
      Thanks for your input, TVTimmy! I am very obsessive when it comes to squeezing the most image quality out of my TVs and that means performing a proper calibration for each one. It involves quite a bit of time and effort using colorimeters, slides and dedicated software like CalMan so if there is no need to repeat the process, I would be relieved. I know the main/A board has the color management bits but I am not sure If these boards are all uniform in that regard or have enough variation to warrant recalibration.
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • tuner2000i
        Philips 65PUS8518/12 distorted image after main board replacement
        by tuner2000i
        hello everyone,
        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
        07-15-2025, 01:15 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
