Sony XBR-55X900E turns off randomly
  • norayr
    • Mar 2018
    • 11
    • Armenia
    Hi Experts,
    I wonder who has experience with repairing Sony Bravia TVs?
    I've got XBR-55X900E Android TV. It has latest firmware update. After a week or so, it started to turn itself off.
    Before turning off, picture is standing still for few seconds, sound may go on, the after few seconds it turns off.
    Sometimes it turns off then back on and is staying on SONY logo. Will not boot.
    When it turns off, I can't turn it on right back. Need to do power reset and it may require up to 15 or more minutes I can turn it on.
    And at one occasion when I was doing factory reset, background behind rings got greenish.
    In service center they are telling that most probably it is a processor, but that is just a clear guess.
    There is no error listed in TVs service menu, error log.
    Please also see following videos illustrating the problem.
    https://drive.google.com/open?id=1Sg...NWasr0zF3hxD0R
    https://drive.google.com/open?id=17a...0DOV2AzeDhyzww
    Want to say that TV may run fine for 2 days, and start turning off on third. Than after night, it will work OK again. So behavior seems completely random.
    Can someone tell if this really sounds like a processor? Should I go blind and replace main board?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: Sony XBR-55X900E turns off randomly
    it could very well be a cold solder joint under the main IC on the main board. Seems like it is a new TV. Does it have any warranty left?
    • norayr
      • Mar 2018
      • 11
      • Armenia
      It's a new TV. Bought in USA shipped to Armenia. So no warranty. So, do you mean the main chip, which is BGA packaged chip, needs to be removed and solder on main board again?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        You could remove the Main Bd. from the TV and heat the BGA chip for 10mins @ 350degrees using a hot air station. I've done this with several LG TVs but have not come across this issue with a SONY. It seems like you have a cold solder joint on the BGA chip, so I think using a Hot air station will solve your issue.
        • norayr
          • Mar 2018
          • 11
          • Armenia
          Thanks for the inputs. Can you send a link to video how this procedure is done? I don't have PCB engineering experience. Only chip design
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            No I don't have a video to share. I am hoping another Member might be able to help.
            • norayr
              • Mar 2018
              • 11
              • Armenia
              So, anyone who experienced such behavior on Sony Bravia before?
              By the way, what were the symptoms for LG TVs for cold solder joint of main processor?
              • nomoresonys
                • 12274
                • U.S.
                Could be a corrupted eprom.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8325
                  Did you try a factory default yet?
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    When the Power button was pressed the set would turn on and shut down Sometimes after a few seconds or after sometimes after a few minutes. Sometimes the stand-by light would just remain flashing in the normal manner to start-up but never started.
                    • nomoresonys
                      • 12274
                      • U.S.
                      https://www.youtube.com/watch?v=RRoXRtzbezY video of eprom fix.
                      • norayr
                        • Mar 2018
                        • 11
                        • Armenia
                        Sure. Factory reset is not helping.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8325
                          my bet is on the main IC or the eeprom. When the TV crashes next time take a can of air upside down or freeze spray and freeze the eeprom first and turn the TV on. Same thing with the main IC. Other than that, try reflowing the main IC.
                          • zomi
                            • Nov 2011
                            • 509
                            https://us.en.kb.sony.com/app/answers/detail/a_id/75705
                            reset tv
                            • norayr
                              • Mar 2018
                              • 11
                              • Armenia
                              Not helping. Did several times.
                              • norayr
                                • Mar 2018
                                • 11
                                • Armenia
                                I wonder what common issues you have faced with this model: XBR-55X900E?
                                What are typical failures on this model.
                                • nomoresonys
                                  • 12274
                                  • U.S.
                                  Maybe the new firmware is buggy, any way to get the old firmware back?
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    Do you have a Hot Air Station?
                                    • norayr
                                      • Mar 2018
                                      • 11
                                      • Armenia
                                      Unfortunately not.
                                      I wonder when you blow hot air onto the chip, how other componemts are not getting loose and not detaching from the board?
                                      • norayr
                                        • Mar 2018
                                        • 11
                                        • Armenia
                                        I don't know how to do the downgrade.
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • NanoTesting
                                          Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                                          by NanoTesting
                                          I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                                          With charger it turns on, fan spins but gives no image.
                                          Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                                          Reflashed BIOS, same problem.
                                          Replaced both main mosfets.
                                          Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                                          10-30-2024, 10:48 PM
                                        • thedigi321
                                          I have an LG 50PN4500-UA turns off and on randomly with 2 flashes before turning on
                                          by thedigi321
                                          showing power does nothing randomly turns on with 2 flashes: https://youtu.be/ZHME8GthErc
                                          Hello all I have an issue with my tv. I have had it for about 5-6 months because when I moved apartments the previous owner left the tv. and I got it for free it is a plasma tv and looks nice enough. an issue that started to happen was that it would kick off randomly but I could still turn it on well about a month or so I assumed the power button went out so I got a universal remote and programmed all lg codes and nothing just the solid red standby light so fast forward to a week ago...
                                          12-18-2019, 10:00 PM
                                        • cheeky2
                                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                          by cheeky2
                                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                          01-08-2024, 05:56 AM
                                        • nieljosiah
                                          HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
                                          by nieljosiah
                                          I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
                                          08-17-2024, 02:19 AM
