Panasonic Viera TX-P42VT30E TNPA5330 blown
  • WildPuppy
    • Mar 2018
    • 61
    Re: Panasonic Viera TX-P42VT30E TNPA5330 blown
    I know, but right now I (or the authorized service) don't have it.
    I'll order one to have on-hand, just in case...
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      You could buy a SS board and use those parts. These boards have all the parts you need. They are cheap because they never fail or buy FGD4536TM from ebay.
      • WildPuppy
        • Mar 2018
        • 61
        I still have the order of FGD's placed, but they will arrive withing 2-3 weeks...
        I thought about buying SS boards, but I think I need two to cover all 6 FETs. I am not sure right now.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          I will check to see how many are on the SS board when i get home. I got a few of these boards.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            I googled on TNPA5331 and there are 6 fets on the board you can use
            • WildPuppy
              • Mar 2018
              • 61
              #26
              Thanks for the tip about SS-boards, I'll keep an eye out in case of repeated problems.
              Hopefully final update:
              TV ran ok until now (about 4 hours). Re-assembled everything, started up, all ok.
              Temperature in the area of the FETs is about 30-35degC at case surface, 35 with very bright pictures and a lot of ambient light (outside of the TV, K thermocouple taped to case).
              Hopefully that DG302 from the shitty kit will hold, as I am sick and tired of taking out all those screws
              Many thanks to all that contributed, special thanks to Moreno83.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #27
                You are welcome! I am glad you fixed the tv , great model with very nice picture quality. How is the burn in?
                The DG302 is probably ok otherwise you would have had 6 blinks.
                Did you check the contacts on the back of the sc board? Usually they are black because of arching....
                You can recognize the fake parts by the logo. The Fairchild circle on original components are engraved in the fet. The fakes just have a stamp.
                With isopropanol or nail polish remover you can wash off the logo from fake parts. Original parts the logo will get visibly better....
                Another great panasonic saved from the bin.
                • WildPuppy
                  • Mar 2018
                  • 61
                  #28
                  Indeed, great colors, beautiful image. There are some slight burn-in marks in the corners, where the channel logos usually sits and in the bottom area where the subtitles are, but not visible under normal watching conditions. They do show up tho on a full white picture...
                  That was the first thing I did after taking out the boards. Indeed, scorching occurred on all three planes of contact, the metal chassis, the board and the screws undersides. Cleaned the chassis and the screws with sand paper and took out the affected solder on the board.
                  • WildPuppy
                    • Mar 2018
                    • 61
                    #29
                    I'm happy to report that the kit DG302 transistor holds up just fine, the TV is still working great after these few days. I imagine that if it was to break, it would have done so by now.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      #30
                      Yes the DG302 is probably a good part.
                      • Ama Chur
                        Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                        by Ama Chur
                        After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                        02-21-2025, 08:12 PM
                      • BigPete
                        Panasonic Heatpump Dryer Repair
                        by BigPete
                        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                        Unfortunately the whole machine has to come apart to fix it.
                        I have...
                        11-01-2025, 06:40 PM
                      • badcappo
                        Dead Panasonic Viera TX-P65STW50 Plasma TV
                        by badcappo
                        Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                        Diode type G972s6 - D101 with a short
                        Mosfet 06N90E - Q301 shorted
                        Fuse T5AH 250V - F103 blown
                        Diode D301 shorted
                        Relay DG1U-17VDC II - RL001 blown
                        I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                        11-24-2024, 11:27 AM
                      • J8rda7
                        Panasonic Viera TX-L50E6E - no image
                        by J8rda7
                        the TV has a black screen. Sound OK, backlight OK.
                        When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
                        I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
                        Thanks to anyone who can guide me in solving the problem.. and be patient with my english πŸ™‚πŸ˜
                        05-13-2024, 11:04 PM
                      • Andre Gilbert
                        by Andre Gilbert
                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                        11-20-2024, 08:52 PM
