LCD42V88P Manual/Schematic
  • adlui
    • Mar 2018
    • 14
    • Philippines
    Hi!
    I'm looking for manual of LCD42V88P board( RASG7.820.2240) and Power board is RASG&.820.1673.
    Symptoms:
    - When switched-on, power led turns red,after few seconds, it will blink 5 times then off.
    - has complete supply voltage on power board socket XP803 and XP805, except STB pin=2.5vdc.
    Any help will very much appreciated.
    Re: LCD42V88P Manual/Schematic
    If you upload good clear straight shot pictures of the top and bottom side of the power supply, and the the pictures of the whole back side of the TV showing all the board; that will help troubleshooting the problems.
      • 12116
      • U.S.
      https://elektrotanya.com/?q=showresult put model number in, might have one.
      • adlui
        • Mar 2018
        • 14
        • Philippines
        @budm:
        https://www.4shared.com/photo/u0dklj...22_104018.html
        https://www.4shared.com/photo/d6Gwuq...22_104052.html
        https://www.4shared.com/photo/kTpG1R...22_104105.html
        https://www.4shared.com/photo/7zdHK4...22_104117.html
        @nomoresonys:
        Thanks. I'll try that link.
        Ooppps.. by the way, this is DEVANT 42CL900.
          So your power board is 'RASG7.820.1673', right? I cannot see it from the pictures.
          Not 'RASG&.820.1673'.
          Are there label for each pin of the connector? They may have label on the bottom side of the board so we do need the pictures of the bottom side of the board too, the more details you give us the better we can help you since we do not have the TV in front of us to look at.
            This looks to be your power supply board:
            http://www.shopjimmy.com/dynex-122904-power-supply.htm#
            Dynex 122904 (RSAG7.820.1673/ROH, 122906) Power Supply Unit
            If it is then I may be able to use the pictures from shopjimmy.
            Pictures provided by shopjimmy.
            I cannot read all the pin names on your board or SJ board so you need to provide us those names.
            BTW, it looks like SJ board is not the exact match, connector XP803 is not the same as yours.
            The SJ board only has switched 16V on XP803 .
            Connector XP805 pins are:
            • adlui
              • Mar 2018
              • 14
              • Philippines
              Yes..that's correct. 1673..it's just typo-error on rsag7
              Pics
              https://www.4shared.com/photo/GiJgS-...2_1128241.html
              https://www.4shared.com/photo/MFTyyD...2_1128541.html
              https://www.4shared.com/photo/6G0DsZ...2_1129201.html
              https://www.4shared.com/photo/wf4a1z...22_112920.html
              • adlui
                • Mar 2018
                • 14
                • Philippines
                hmmnn.
                SJ has ver E, mine was ver F
                • adlui
                  • Mar 2018
                  • 14
                  • Philippines
                  Update.
                  Lift STB pin, voltage becomes 5v( 2.5v when connected.) and Standby LED remains On now(normal standby).
                  STB voltage is always on. No response from POWER "touch" button.
                    STB pin is the control signal pin, it is the same as PS-ON, in your case this will turn on the power relay (right next to C848) so the switched 24V , 16V, etc, will run. 2.5V = Main power supply ON, <1V = Main power supply OFF.
                    5V_S is the 5V Standby power supply to run the main board and it must be working otherwise you will not have 2.5V at the STB (PS-ON) pin to turn on the power supply. Verify that you do have 5V at 5V_S pins.
                    So do you hear the power relay click sound when power switch is activated?
                    • adlui
                      • Mar 2018
                      • 14
                      • Philippines
                      Yes, relay clicked when main switch turned-on and has 24v, 16v,12v,etc... STB 2.5V but, touching power button, it didn't turn to 0v.
                        So at this moment the TV is stuck on since the main relay is on and getting all those Voltages. Can you use your remote to turn the TV on and OFF?
                        Does the 24V/16V/12V goes away when power switch is toggle on and off?
                        Do you have backlights at this point?
                        • adlui
                          • Mar 2018
                          • 14
                          • Philippines
                          Yes, the TV is On but there's no display or indication that the system is completely boot-up.
                          24v/16/12v goes off because there's only main power switch option to turn on and off.
                          -Unfortunately no available remote control.
                          Sometimes after repeatedly toggle ON/OFF switch, just a dimmed backlight.
                            If the PS-ON is stuck on then you have problem in the main board some where, but the BL-ON signal is present otherwise you will not get any backlights at all, so is the BL-ON signal stuck high too then?
                            • adlui
                              • Mar 2018
                              • 14
                              • Philippines
                              Yes, PS ON is always "high" right after main power switch is ON.
                              BL-ON signal was intermittent associated in switching main power switch..
                              There are times, when main power switch turned-on, it has "high" signal, sometimes no signal.
                              • adlui
                                • Mar 2018
                                • 14
                                • Philippines
                                up..
                                  • 12116
                                  • U.S.
                                  Wonder if the firmware on mainboard is corrupt.
                                  • adlui
                                    • Mar 2018
                                    • 14
                                    • Philippines
                                    I think you've got it right. That's another thing I will try.
                                    But, I can't find eeprom file for this board.
                                      • 12116
                                      • U.S.
                                      https://devanttv.com/products/
                                      Do you see your model there? maybe hit the contact there, email or call see if they have the firmware available.
                                      • adlui
                                        • Mar 2018
                                        • 14
                                        • Philippines
                                        Thank you.
                                        I can't see 42LC900 model on their list but I'll try to contact them if they can provide fw file.
                                        • Grouickman
                                          Hofmann geodyna 6300 Wheel balancer
                                          by Grouickman
                                          Hi there,
                                          First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                                          Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                                          I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                                          I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                                          03-31-2025, 05:29 AM
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • Garret Matt.
                                          DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                                          by Garret Matt.
                                          I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                                          Thank you in advance for any assistance you can render.
                                          Inductor In question. Buzzes like...
                                          06-20-2025, 01:21 PM
                                        • johnbeton
                                          looking for schematic for Acer SP313-51N board Yacht_TL 203022-1
                                          by johnbeton
                                          I'm looking for the schematic for a Acer board Yacht_TL 203022-1
                                          The board had some minor liquid damage.
                                          I have no shorts, have 3v, 5v, 3.3v, ... but no leds or power on.
                                          When touching certain parts of the board with my finger, the powerleds go on or start blinking.
                                          11-11-2024, 04:59 AM
