Replaced individual LED with resistor....but how?
  • JDC
    • May 2015
    • 273
    I'm sure this has been addressed many times before, but if I wanted to replace an LED with a resistor, how would I go about determining the right value?
    I know how to replace them with other LEDs.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Replaced individual LED with resistor....but how?
    Is this LED the backlight for a TV? If yes I would suggest a diode instead of a resistor. The resistor depending on the Current and Voltage would have to be a physically large one that would dissipate heat and eventually destroy the PSU and the polariser sheets etc.
    • JDC
      • May 2015
      • 273
      Sounds good! So...a 3.3v diode?
        At least 2W 3.3V Zener connected in reverse bias.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Originally posted by budm
          at least 2w 3.3v zener connected in reverse bias.
          +10
          • JDC
            • May 2015
            • 273
            Thanks!
              Resistor and zener would do the same in this application, a resistor would handle the power better.
              But to know the value of the resistor you need to know the current and that's not always easy to measure.
                The current is set by the Backlights level setting so Vdrops on the resistor will keep changing so the overall Vf will changed more compared to if the load is all LEDs which the Vf will vary not very much (have to look at the Vf curve VS current).
                • Dumah Brazorf
                  • Jun 2013
                  • 179
                  • Italy
                  Are leds all connected in series or are there some groups in parallel?
                  In the first case, assuming the led driver is current driven, you can simply short the bad led out.
                    The LED are fed with constant current using constant current control element (PWM Controlled MOSFET which is connected to the Cahode return of each LED string) in the low side (sink) so if you bypass the bad LED that means there will be more Vdrops on the MOSFET which can cause it to overheat.
                    • Dumah Brazorf
                      • Jun 2013
                      • 179
                      • Italy
                      It's only one led less...
                      More important is to teach the customer to set the brightess no more than 70-80% if they don't want to kill the others soon.
                        That's true but the current will be constant. The backlight current is usually PWM rather than direct modulation. In any case, if it is modulating the actual current, then it won't make much difference as long as you design it to work well at the full current setting. Any power dissipation increase in the driving transistor, for a couple of LEDs, will be absolutely marginal. Whereas a resistor will handle the power dissipation better.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8352
                          I only can say that IF I replaced a bad LED with something else in backlights, it always was a Zener diode in reverse bias as budm suggested. The resistor is too much headache for my liking.
                          • chrismurphy
                            • May 2014
                            • 251
                            • australia
                            5 x IN4004 diodes in series or similar work well, but don't use a resistor
                              https://www.badcaps.net/forum/showthread.php?t=46403
                              5 diodes for LED.
                              • JDC
                                • May 2015
                                • 273
                                Where's a good place to get a few 2W 3.3V zener diodes?
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8352
                                  digikey, ali, mouser, element14, allied etc...
                                  • jetadm123
                                    • 2169
                                    Try a 1N5333 zener. Rated 3.3V @ 5W. Readily available and a little more mainstream than a 2W zener.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8352
                                      1N5913 3.3V 3W zener at digikey part #: 1N5913BRLGOSCT-ND
                                      4523 in stock
                                      • jinu_j
                                        by jinu_j
                                        Hi
                                        05-03-2025, 10:51 PM
                                      • mikey5791
                                        by mikey5791
                                        Hi to all forum members,
                                        12-26-2024, 04:55 AM
                                      • MidnightRoller
                                        Can a resistor lose resistance after hot air?
                                        by MidnightRoller
                                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                        02-02-2022, 11:46 PM
                                      • artvandalai
                                        What resistor ohm will work better to repair this waterpik?
                                        by artvandalai
                                        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                        01-05-2025, 04:10 PM
                                      • flat-earther
                                        Hoover FM216LI cordless vacuum refuses to charge
                                        by flat-earther
                                        I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                        I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                        5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                        So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                        06-06-2025, 03:14 AM
