Lg 47lw5300 main board
  • Jackching
    • May 2017
    • 127
    Just wondering if anyone knows if this board https://www.aliexpress.com/item/HENR...ceBeautifyAB=0 would work in a 47lw5300? Or does anyone know of anyone in canada that repairs the eax64290501 (0) boards?
  • CapLeaker
    Leaking Member
    • 8146
    Re: Lg 47lw5300 main board
    That mainboard is different than yours. It doesn't have 3d, the tuner is different etc. Even if you could resurrect the old TV somewhat (if that new main board supports your panel) it wont have the same features it once did. I'd pass on that main from ali.
    • Jackching
      • May 2017
      • 127
      Here are the pictures of the board. All of the voltages checked with a volt meter came back correct except the PWR-ON. It is supposed to read 24V but came back 3.4V. This looks like a main board issue doesnt it?
        • 12181
        • U.S.
        https://www.ebay.com/itm/REPAIR-SERV...4AAOSwstJZUmOp
        LG mainboard repair service, haven't used this service myself but they have 100 percent positive feedback.
        • vinceroger69
          • Mar 2012
          • 6714
          i think pwr on at 3.4v is correct the other pins should read 24v whats the fault with your tv?
          • Jackching
            • May 2017
            • 127
            I got it going. All voltages were correct so I assumed main board. When i applied small pressure to the main board, L497 was sparking so i touched it up with some solder and it didnt anymore plus i did the hair dryer trick on the bga for approx 4 mins. The tv was not coming on.
            • vinceroger69
              • Mar 2012
              • 6714
              if it fails again you may need to get the bga re flowed properly some people have success using a heat gun/flux too maybe or check on ebay see if theirs a services to reflow it for you if you cant do it yourself.
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
              • JDC
                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                by JDC
                ONN 100012588
                Issue: No Power, Then Rebooting After Main Board Change
                Short answer: replace main board and power board
                Technical answer: replace main board and Q306 & Q307 on power board.
                Long answer:
                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                07-15-2022, 07:39 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
